Mating a later 3-speed to a y-block
Hey guys. I have a '61 F100 292 y-block with non-syncro'd 3-speed on the column.
I know of two other F100's that are a little newer (one is a '67 with a 300 and the other is a '68 with a 390) that have syncro'd 3-speeds with overdrive. My question is, if I could find one of those could it be made to work with the y-block in my f100? If so, what would it take? Surely someone has done this before. thanks Michael |
Originally Posted by Mikulh
...that have syncro'd 3 speeds with overdrive. :-huh
The Borg Warner T-85N 3 Speed Manual w/Overdrive was an option in 1965/71 F100's. It does not have 1st gear syncro, so it is not an all syncromesh transmission. 1961/64 F100's were available with the optional Borg Warner T-86 3 Speed Manual w/Overdrive. It's not an all syncromesh transmission either, only the following is: Ford type 3.03 3 Speed Manual all Syncromesh Transmission (no O/D) introduced in 1963 F100/250's with 223's & 292's. To install one a these, find a 1963 or 1964 F100 (preferably a 1963) that is similar to a 1961/62 F100, get the trans, linkage, driveshaft and other necessary parts from it. This trans was used from 1963 thru 1987 in a gazillion applications, including Ford/Merc Passenger Cars, F100/350's (F350's after 1966), Bronco's and Econolines. But only 1963/64 F100's will have all the correct parts to install one a these type 3.03's in a 1961/62. |
Bill, did the all synchro 303 ever come with an OD? I thought the ODs were on BW boxes only.
No transmission manufactured after 65 will fit the Y blocks bell pattern for three speeds.
Garbz |
Originally Posted by garbz2
(Post 11154117)
Originally Posted by 85e150six4mtod
(Post 11154049)
Bill, did the all synchro 303 ever come with an OD? :-huh
I thought the ODs were on BW boxes only. :-X22 My 1965 F100 had the T-85N. You either double clutch into 1st gear, or wait until you came to a dead stop. I prefered the "old timey" double clutch method. O/D kicks in/out between 30-35 MPH |
(Post 11154020)
No such thing as a 3 speed manual all syncromesh transmission with Overdrive. If the above 3 speeds are all syncro, they do not have Overdrive.
The Borg Warner T-85N 3 Speed Manual w/Overdrive was an option in 1965/71 F100's. It does not have 1st gear syncro, so it is not an all syncromesh transmission. 1961/64 F100's were available with the optional Borg Warner T-86 3 Speed Manual w/Overdrive. It's not an all syncromesh transmission either, only the following is: Ford type 3.03 3 Speed Manual all Syncromesh Transmission (no O/D) introduced in 1963 F100/250's with 223's & 292's. To install one a these, find a 1963 or 1964 F100 (preferably a 1963) that is similar to a 1961/62 F100, get the trans, linkage, driveshaft and other necessary parts from it. This trans was used from 1963 thru 1987 in a gazillion applications, including Ford/Merc Passenger Cars, F100/350's (F350's after 1966), Bronco's and Econolines. But only 1963/64 F100's will have all the correct parts to install one a these type 3.03's in a 1961/62. Or does my transmission have them and they're just worn out? |
(Post 11154280)
You are correct. The ones I was talking about don't have syncro'd 1st gears... but they do have syncro'd 2nd and 3rd gears, which my transmission does not seem to have. :-huh
Or does my transmission have them and they're just worn out? :-X22 It would be far cheaper (and waaay less labor intensive) to replace the two blocker rings, 3 syncro shoes, snap rings, gaskets, front/rear seals, than to swap trannies. Besides, the used tranny you buy may not be any better than the original, could be a lot worse. |
(Post 11154432)
That is the approach I will take. I wasn't aware that mine was even supposed to have syncros. How complicated is it to replace the parts in question and where would I get them? Can I do it with basic hand tools or would I need access to a press? |
(Post 11154432)
Besides, the used tranny you buy may not be any better than the original, could be a lot worse. Garbz |
(Post 11155636)
Thanks for the help.
That is the approach I will take. I wasn't aware that mine was even supposed to have syncros. How complicated is it to replace the parts in question and where would I get them? Can I do it with basic hand tools or would I need access to a press? I would purchase a shop manual if you do not have one, as it describes the procedure to replace them and has good reference drawings of the gears and how they relate. Garbz |
Thanks. Good to know.
I have a shop manual I just didn't realize that would be in there. I will check it out. Where can I buy the the two blocker rings, 3 syncro shoes, snap rings, gaskets and front/rear seals? |
