1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
What rear end do I have in 98 expedition xlt
Old 12-12-2011, 10:01 PM
hodges710's Avatar
hodges710
hodges710 is offline
I am going to be doing some work on my rear end, I went under it to see if I could get any info to help my identify the rear end with no luck. I then looked at a parts mag. that shows most of the rear ends from Ford and others and my bolt pattern does not match up to what I though i had (8.8). I could not find the bolt pattern that I have, so is there anyone out there that can help.
Old 12-12-2011, 10:58 PM
Krazy351w's Avatar
Krazy351w
Krazy351w is offline
maybe try looking up your axle code located on the driver door
Old 12-13-2011, 06:27 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
...or on the tag under one of the axle cover bolts...
Old 12-13-2011, 07:04 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Old 12-13-2011, 02:51 PM
hodges710's Avatar
hodges710
Originally Posted by alwaysfords41
ok this tells me that my ratio is a 3.55 but i still dont know what rear end i have. Through the site you gave me, I still cant match up the bolt pattern to know what type of rear end i have. it did show a 9.75 for 97 and up expeditions but the bolt pattern is way off from what I have.
My bolt pattern matches up the the 9 but that actual rear end was not used unless i read some wrong info.
Old 12-13-2011, 03:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
9" rear axle = 1957/79 misc. FoMoCo Passenger Cars / 1957/82 F100, some 1983 F100 / 1966/82 Bronco, some 1983/86 Bronco / 1969/87 E100/150 / 1975/82 F150, some 1983/86 F150.
8.8" rear axle introduced in 1983. Some F100/150's & Bronco's could also have the 8.8 as it depended on the application.
1997/2001 Expedition could have either the 8.8" or 9.7" rear axle with or without Limited Slip. Post the AXLE code printed on the Certification Label.
Posi, Positraction are GM terms.
Old 12-13-2011, 04:07 PM
alwaysfords41
The posi term came attached to the link I posted, which is the result of someone else's search. Here is a decoder for the axle codes;
1998 Ford Expedition Used Rear Axle Assembly (Genuine OEM Quality)
It looks like the 3.55 is a 8.8
Old 12-13-2011, 05:12 PM
hodges710's Avatar
hodges710
my axle code is 19.
Old 12-13-2011, 05:13 PM
NumberDummy
Correct, I looked in both the 8.8 and 9.7 rear axle parts lists.
Only ratio listed for the 9.7 = 3.31-1.
I go by Ford truck parts catalogs to decode this jazz. The aftermarket sector decoders could have errors and omissions.
Old 12-13-2011, 05:15 PM
hodges710's Avatar
hodges710
thanks for the link
Old 12-13-2011, 05:20 PM
hodges710's Avatar
hodges710
ok, thanks for the replies and help. Its nice to know what rear end i have, how is the 3.55 anyways, I mean where does it stand among other common ratios. I hear alot about a 4.10, 3.73 and a few others.
Old 12-13-2011, 06:06 PM
hodges710's Avatar
hodges710
now knowing that my rear end is an 8.8 with a 3.55 ratio, what is the front axle assembly. I know being a 4x4, the ratio is the same, just curious on the name of this axle assembly as well.
Old 12-13-2011, 08:48 PM
alwaysfords41
Ummmm, 3.55 front axle. There are no size variants in the front.
Old 12-14-2011, 09:10 AM
hodges710's Avatar
hodges710
I wasnt asking if the front had a different gear ratio, i was asking what the name or type of the front axle.
Old 12-14-2011, 10:41 AM
alwaysfords41
Not really sure what you mean. There is no name for it other than 3.55 front axle. Name it whatever you like.
Quick Reply: What rear end do I have in 98 expedition xlt
