Removing AIT2 sensor
on
i see the theory behind it, but I dont think thats your issue. try pluging in the block heater for a few hours and see what happens. most lack of power cold start issues are related to injecotrs and ficms.
if you have a way to read pid data compare iat1 to iat2 and you should see iat1 a few degress hotter then iat2 with the key on and engine off when prior to running the engine. if you run it for a little bit you will see iat2 pass iat1 readings. then command the egr valve open and iat2 should incress further.
ChristopherN
12-04-2012 11:17 AM
NitrogenTSRH
10-19-2011 05:25 PM
STRANGER RANGER2
01-20-2009 02:46 AM
