Water leak Help please
Old 12-09-2011, 05:22 PM
95PSDieselP's Avatar
95PSDieselP
95PSDieselP is offline
I have a water leak where i believe is in the valley. It only leaks like hell when i use my heater.. any thoughts? thanks in advance
Old 12-09-2011, 05:37 PM
tharepairguy's Avatar
tharepairguy
tharepairguy is offline
Well sounds like it could be on the other side of the shut off valve. From what you described, when you don't have the heat on. That valve should be closed and keeping water from flowing to the spot where it leaks. That valve is controlled by vaccuum and located around the passenger side valve cover.
Old 12-09-2011, 05:38 PM
95PSDieselP
Sweet i will check it out tomorrow. Yeah usually it leaks like crazy but today i didnt use my heater and didnt leak a drop.... what would it take to fix it do you think? prolly just a new hose hm?
Old 12-09-2011, 05:48 PM
tharepairguy
Depends. Could be a hose, the valve itself or just a hose clamp. Should be easy to check the valve area. Nothing is blocking it and should be right on top or next to the pas side valve cover.
Old 12-09-2011, 05:50 PM
95PSDieselP
sweet thanks man i appreciate it
Old 12-09-2011, 06:11 PM
cheezit's Avatar
cheezit
cheezit is offline
check the heater controll valve if you have one. would also have signs of leaking on the #5 injector plug.
Old 12-11-2011, 04:10 PM
95PSDieselP
Ok so i checked the heater valve. dry and tight.... but i think it may be this hose it is my egr hose right??
http://i30.photobucket.com/albums/c3...e/CIMG0064.jpg
Old 12-11-2011, 04:32 PM
tharepairguy
That is the old style EGR hose I believe. The updated hose is blue. Strange that it changes when heat is on. I wouldn't think the valve is inline with the flow from the oil cooler/egr. They usually leak when cold. Perhaps the extra flow through the heater core drops the pressure enough to let it leak around the o-rings.
Old 12-11-2011, 07:06 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
EGR hose and o-ring
Parts list:
4c4z-8592-AA Hose ........$50.80
3c3z-9n693-FA O ring ......$ 6.18
3c3z-9n693-EA O ring ......$ 6.50
Old 12-11-2011, 07:10 PM
amdriven2liv
Good thread on replacing the hose, with a couple pics of tools to use.
https://www.ford-trucks.com/forums/1...e-install.html
Old 12-11-2011, 09:28 PM
tharepairguy
I think I have a brand new EGR hose if you need one. Along with intake gasket set and turbo kit...
All new OEM. If interested, I'll take a look for ya.
Old 12-12-2011, 09:05 PM
95PSDieselP
wow thanks a lot guys a big help let me tell you. yes the hose is leaking i took a look last night. Yeha man if u have em what would u charge for em? give me a message let me know what u can come up with i appreciate this a lot
Old 12-12-2011, 09:08 PM
95PSDieselP
going to harbor freight tomorrow
Old 12-12-2011, 09:27 PM
tharepairguy
I got it from ford @ 10% over cost. Happy to pass the savings onto you + actual shipping cost. Let me double check tonight to make sure that is what I have but 99% I bought an extra 1 that came with something else I got when doing it all.
Old 12-12-2011, 09:28 PM
95PSDieselP
awesome thanks lol @ over cost
Quick Reply: Water leak Help please
