Show Me your Bucket Seats and Interiors
Old 12-10-2011, 09:36 AM
Chris Guthro's Avatar
Chris Guthro
Chris Guthro is offline
Yea, id love to see pics frederic. I like seeing the ways you guys done your interiors! looks nice. I want to know what company would sell the best paint to redo my interior in a tan/gold that these trucks came in.
Old 12-10-2011, 06:08 PM
guitarist41991's Avatar
guitarist41991
guitarist41991 is offline
are you talking about painting the dash and trim? because all of the paint in my interior is covered with trim and carpet. i dont think you can see any paint except when you open the doors
Old 12-10-2011, 11:57 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
Bootlegger's Deluxe is offline
did those seats ever come in Red?
Old 12-11-2011, 06:53 AM
Chris Guthro
Yea all the trim and door panels. I want to have the metal on my roof and behind my seats seeable to because my cabs getting gutted to get painted body color. I need a good paint that would look good on my dash and i could redo all my door panels.
Old 12-11-2011, 07:38 AM
frederic's Avatar
frederic
frederic is offline
I thought we could upload pictures to FTE, but seemingly I haven't done it in so long I couldn't figure it out uncaffienated. Anyway, here ya go:
'89 Chrysler Minivan Seats in the front of my crewcab:
Some of the bracketry/framing I made for the two seats, so that they install as a bench seat:
Another picture of the framing as it goes under the driver's seat. That's the diagonal 1" square tubing that goes underneath the driver's seat just below the black adjustment lever:
And finally, a non-seat picture of the town car column I installed (tiltwheel!) and the Windstar digital cluster I grafted in place of the original.
For the seats, what I did was remove the bench seat from the sliders, leaving the sliders mounted to the floor of the truck. I welded a steel frame out of 1/8" wall, 1" square tubing to go across the bench sliders, which is basically a rectangle with two additional cross pieces that land on the sliders themselves. The frame is then wider than the width of the seat brackets. I then created eight "tabs" and bolted them to the seat mounts of the Chrysler bucket seats, then placed the seats on the frame, so that all four tabs per seat touch the frame I made. Wiggled to alignment, adjusted left and right, then welded the tabs.
The tabs allow me to leave the steel frame and remove the seats individually for repair or replacement, or I can remove the entire frame from the sliders and put the factory bench seat back on top of the sliders with the original four bolts, should I ever want to return the truck to stock.
I probably should have painted the steel frame to reduce surface rust but halfway through the project I was offered a job that afternoon so as often is the case, I rush through things to get it back on the road, "now" with the intention of getting to it later, and never do.
Sorry for the really big pics... I thought facebook resized them as they once did. Oops
Old 12-11-2011, 08:51 AM
kd0axs's Avatar
kd0axs
kd0axs is offline
Here's what I had in my 95 F-150. Leather buckets with power and heat out of an Explorer Sport Trac. Got the console off eBay, don't know what it came out of.
Old 12-11-2011, 10:32 AM
downhillpat's Avatar
downhillpat
downhillpat is offline
I may get flamed for this but...easiest seat swap ever....Some idiot cash for clunker'd a 93 lightning....apparently it was all rotted... well, at least the seats from it have a use. I had to replace the wire mesh support in the middle of the seat, and welded the broken recline handle, pulled all the foam and covers, washed with tide, hose and scrub brush, came out great.
Old 12-11-2011, 10:42 AM
awils961's Avatar
awils961
awils961 is offline
@Jonbar87 damn that is one hell of a nice interior, i bet that took a while. @frederic how'd you get the digital display, that looks awsome.
Old 12-11-2011, 10:49 AM
Bootlegger's Deluxe
I'd love a set of L seats ... they'd fit great in my 95
Old 12-11-2011, 12:56 PM
frederic's Avatar
frederic
frederic is offline
Here's what I did, more or less step by step: F350/Windstar Cluster Swap
Because the trucks lagged behind the cars (including minivans) in electronics, slightly older-year minivan clusters are fairly easy to swap into the F-series. The key is to find a digital cluster that reads analog sensors, rather than display information provided from the computer only.
The mounting ears even lined up, and when I bought the windstar cluster I pulled a piece of the harness out with it, then mapped the pinout of the windstar cluster to the original F350 cluster, and adapted it that way.
The only caveat is the windstar was a V6, and my truck is a V8, so the tachometer is always off by 25%. I didn't need a tach so it being "off" doesn't bother me in the least because I never had a tach in this truck until I added the digital cluster.
I wanted digital because it's far easier to read a giant glow-in-the-dark "65" at night as compared to having to tilt my head to see where the needles are pointing, because I wear bifocals.
Old 12-11-2011, 01:51 PM
awils961's Avatar
awils961
awils961 is offline
Nice, you could tweek the tach, so it is accurate, but then agian, it realy doesn't matter that much. but nice job though, it looks realy nice.
Old 12-11-2011, 05:45 PM
Chris Guthro
kdOaxs, thats the cleanest interior and a similar seat to the one im getting. But mines gold/tan. that console looks to be out of a 90s chev ex cab. I have a similar one but am using one from a 2001 super cuty. I like how you mounted your cb to it. got any pics of that bracket? thats a sharp loooks digital cluster too frederic!
  #28
Old 12-11-2011, 08:30 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You dont have shoulder belts?
  #29
Old 12-13-2011, 03:36 AM
Thumper19's Avatar
Thumper19
Thumper19 is offline
Originally Posted by Diesel_Brad
The 94-97 40-20-40 will bolt right into a 80-97 truck. NO DRILLING.
The ONLY catch is... the 40-20-40 has to come from a reg cab or crew cab. SUPERCAB brackets are different.
Wrong, see above
Thank for the info man! I will be seat hunting at my local junkyard
  #30
Old 12-13-2011, 07:00 AM
kd0axs's Avatar
kd0axs
kd0axs is offline
Thanks!
Unfortunately, I don't have the truck anymore so I don't have any more pics. If you are wondering how I mounted the CB bracket, I just ran some sheet metal screws right into the plastic.
When the guy at the junkyard told me I could have those seats for $150 if I pulled them, I didn't have to think twice. The hardest part about putting them in was figuring out the wiring for the power and heat. I was kind of thinking the console looked like a GM style, but I got it for $30 off of eBay so I didn't really care what it came from.
juang316
17
04-07-2016 03:39 PM
Killer RC
06-29-2011 11:39 PM
flaireside95
16
01-16-2004 06:23 PM
Quick Reply: Show Me your Bucket Seats and Interiors
