Odd misfire between 1k and 2k rpm, under only moderate accel
So, my 2004 with its constant tick is now "Missing", but only under moderate acceleration, between 1k and 2k rpms. ie: When in OD and wanting to gain a few MPH, but not drop down a gear. I have noticed it in OD and in 3rd. Feels like the engine stops for a split second, several times. Any Ideas?
Figured it out on my '04 5.4 Lariat. Had exact same problem. Did the plugs last week and the problem went away 100%. Old plugs had way over .080" gap on them (.080 was my largest gap tool wire). Used the Sp515 Motorcrafts to replace. Took out for a 100 mile highway drive and didn't have 1 misfire at all.
I am having the exact same issue in my '06 FX4 SCREW. Been happening for about a year and getting worse. It s now doing it on the highway between 60 and 75 mph. It started on the 40 to 50 mph range originally, and usually on a slight grade with light throttle pressure.
Took my truck last week to a referred mechanic and he hooked up his $4000.00 plus dollar Snap On scan tool. I had figured coil packs for mine from all of my reading on here. The coil packs are perfect, but four of the eight plugs have a voltage drop with two of them being significant.
He was very confident in his diagnosis and ran multiple tests to confirm and even disconnected two coils packs to confirm everything since I had no stored codes or a check engine light on. The disconnected coil packs threw codes, which we then cleared.
I am scheduled to go to him next Tuesday the 10th and swap out all 8 plugs. I will let you know how the truck runs after that. By the way I have 89,000 miles on mine right now.........
Also I have the 5.4 Liter 3 Valve non Flex Fuel engine
Hello i have similar issue Misfire on cylinder #4 2007 4.6L XRT i have change all coil packs spark plugs, still doing same issue very rough idle checked voltage to coil packs and injectors all good even put transmission fluid in engine to see if a valve or lifter was stuck changed oil same issue dealer can't find issue even changed the box under the spare tire. could anyone help please I'm thinking of scraping the dam truck has 155 000 km no mileage at all.
Lucky you i have change 3 different kind of spark plugs went to the dealer have them installed the one from ford and they changed my coil packs twice the first set i bought were after market then went at ford replaced them with theirs and I'm at 1200$ still can't find issue love the truck but ..
This has been covered many times . Ignition problems - bad plugs /boots /bad coils corroded tabs on cops . Connectors not locking on due to bad plastic /heat etc splice new ones in and solder . Liquid or dirt in wells very bad .
The code will not set until it gets real bad ,threshold is high . You can see what cyl are building towards setting a code with mode six on a code reader . Torque pro $5 app -android phone - cheap bluetooth reader amazon- under test results . . The problem shows up with a faulty ignition in od with engine lugging . Like climbing a small hill in high gear .
Raw computer counts if ignition good should be zero .
Missfires in OD over 45 mph can be diagnosed with a Scanner looking in Mode 6 at the misfire counter for each cylinder.
The misfires usually indicate faulty coils.
The issue occurs under the specific driving conditions when fuel mixture goes very Lean by design.
This raises the voltage requirement from the coils.
If any coil cannot supply the required higher voltage, missfire results (studder).
Most often the faulty coil has shorted turns lowering the voltage. This is not a hard fault and will not set a code when the driving condition is exited because the PCM cancels the requests as the faulty operation is not present.
In some cases, the faulty coil can put gabage out on other lead that gets back to the PCM.
When this hapens, >>remember the full drive train is still hooked up<< when it happens. The PCM STOPS processing and leaves everything as it was when it stopped.
The result can be violent jerking action until the PCM begins processing again and runs the motor as if nothing had happend, until the next time.
Because the drive train is still forcing the motor to turn over, the Crank sensor will pick up the timing and continue to put out control pulses and run the motor again.
Sometimes plug replacement will tend to clear it only to come back again 600 to 1000 miles later when the plugs begin to errode, then the studder begins all over again due to faulty coils.
Don't use ACCELL coils. They are Chinese made and have a high failure rate.
The following users liked this post:
Couple year old thread and this topic is well covered EXCEPT what if it isn’t any of the mentioned above (coil, plug, boot, liquid in cavity, fuel pressure..
my 99 v10 is low on power, drives better with OD switch off but that just keeps it from shuddering while it misses (for the most part). Cylinder 4 misfire with mode six.
Tried
cheap coils
used motorcraft coils (from my 2v mustang, same part)
full set of new motorcraft coils/boots from parts store
auto lites and motorcraft plugs
zip tire on all coils
zip tire on all injectors
good fuel pressure at idle and under load
still misses and shudders and low on power and shows miss on cylinder 4 and sometimes 7.
idles alright. Might have a little shake but when disconnecting one coil at a time it changes with every one of them.
30 to 40 with light pedal and lower rpm’s feels like I’m going over a king continuous rumble strip.
there is a calvan insert on cylinder 4 but I’ve pulled all the plugs and coils and swapped them around with zero difference.
did valve stem seals and hydraulic lifters (lash adjusters), took care of oil consumption and the ticking sound.
only shows a miss on my scan tool when it’s actually shuddering and under 2k ish rpm’s. If I keep the rpm’s up and it isn’t shuddering then it says no misfires.
no check engine light.
I’ve had the common issues on my 2v mustang, which were solved by the various methods that are always suggested.
any other ideas which weren’t mentioned so far in the thread?
Tried
cheap coils
