What is the biggest motor i can fit in a 94 f-150
>for the biggest motor you can put in your truck? well, how
>big is your imagination
Pretty DAMNED BIG! How about a FAIRBANKS-MORSE 10Cyl 38-D-8-1/8" opposed piston diesel, Turbo charged, AIR START! 1600+hp at 720rpm (wide open!)with a 1100KW GE Generator! Hooked up to a 450V DC Direct drive traction unit! It would fit physically on an 25ft flat-bed. You'd need one hell of a suspension. The pistons each weigh 120#. x 20. Total package about 40 TONS.
250psi roll on air and kick in the fuel rack! Run the governor up to 700 rpm idle till warmed up and then crank it up on load! You wanna see something that SMOKES! This engine will pull 3 city blocks down without trying!
And just think I got access to 4 of these ROCK CRUSHERS! On a WWII Sub!
Hehehehehe!
Hehehehehe!
T_Cooksey88
12-10-2014 08:02 PM
fordman95
08-26-2002 05:33 PM
