Won't turn over - no spark??
made sure you have all the wires on the coil correctly?
It did run like crap then but only because the previous owner did replace the head gasket he blew causing antifreeze to go in the oil. So that being said I rebuilt the engine. Everything is wired up properly and rechecked. Distributor wasn't touched other then pulling it out to rebuild engine. Coil hooked up properly too.
on
So if you have a test light on the pos side of the coil and turn on the key, do you have power? If not you might need a new ignition switch.
If you do have power then check to see if it happens at the correct time.
Mark your dist where the number 1 plug wire is. Then turn the engine over and with the #1 plug out. When you feel compression at TDC #1 note where the rotor is pointing. It should point to the mark you made. If not reclock the dist.
For a engine to run it needs to have fuel, spark, and it needs to happen at the correct time.
If my truck ran before how could I need an ignition switch? Because of the possiblity of no power would mean that the switch would not be letting the power through till the key is turnt to "start"?
If I do have power and it don't happen at the right time what does that mean? Timing? If so, the timing chain wasn't touched.
sometimes when you disturb old wiring (or when a car has sat for a year or more) parts just go bad.
make sure you have power with the key in the 'run' position, and make sure you have power to that wire when cranking. Sometimes you will not have enough power when you are cranking.
you can also put a timing light on while you are cranking to see if you have spark, and you may have better luck getting the timing close to get it to start.
also make sure your battery is charge up real good. I have had many issues solved by just charging the battery.
on
You said you have no spark.
The first thing I would check would be see if there was power to the coil.
You said you took the distributor out.
To make sure it is installed correctly you bring the number one cylinder to Top Dead Center. Then you see where the rotor is pointing, it should point to #1 plug wire location on the cap..
Ben's 77
09-11-2017 02:49 PM
reids59
07-29-2014 03:02 PM
