Window motor repair kit
Yes, take note of the position of the red and the yellow wires with the motor or you might end up with a window that goes down when you press up... The motor itself is quite simple, but be careful with the small and plastic parts. Also, there is a clip where the bolts that keep the motor together rest, it's supposed to be curved, that way it give some tension to the whole assembly, don't straighten it!.
1fordtruckman
10-22-2007 07:44 AM
