Problem removing stuck inner spindle nut
Old 11-25-2011, 04:53 PM
davidsnook1981's Avatar
davidsnook1981
davidsnook1981 is offline
I have a 1991 f150 4x4 5.8 automatic with auto locking hubs. A front right wheel bearing started making noise. Removed the locking hub, c clip, star washer, washer with all the holes too, and outer (first) spindle nut. Problem i have is the inner (second) spindle nut is not moving at all. I have put a 1/2 inch breaker bar and a 3 foot cheater pipe with no luck at all. I used to consider myself a knowledgeable guy but after fighting this truck for 3 days im starting to reconsider my asessment. Please if anyone has a suggestion before i haul this turd to the scrap yard.
Old 11-25-2011, 04:59 PM
bashby's Avatar
bashby
bashby is offline
Sounds like the bearing may have gotten hot enough to weld the nut to the spindle. If you spin the rotor does the bearing make a whole lot of noise? Got a lot of play in the wheel bearing?
Old 11-25-2011, 05:02 PM
davidsnook1981
Yes the bearing does make quite a bit of noise when i spin the rotor and there is a noticeable bit of play in the rotor when wiggled back and forth.
Old 11-25-2011, 05:08 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
Hammer and chisel time and proably new spindle also due to heat damage already caused by the hot bearing.
Old 11-25-2011, 05:10 PM
davidsnook1981
If it is "welded" do i have any options on removal other than cutting torch or similar technique? Definately not a road i want to go down lol.
Old 11-25-2011, 05:11 PM
davidsnook1981
Not what i wanted to hear! Hammer and chisel as in trying to just break it or to turn it?
Old 11-25-2011, 05:17 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
I've got them out by turning them with a large mallet and chisel(sharp) and plenty of force. You will stretch the nut as you make progress so maybe you can salvage something.
Old 11-25-2011, 05:24 PM
davidsnook1981
The problem i think i would run into on the inner nut is it is so far inside that i dont think i can ever hit the darn thing. Want to buy a truck?
Old 11-25-2011, 05:26 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Nooooooooo! the thing after the first spindle nut is a safety washer! you just need to pull it, the washer has some holes where the pin in the second nut fits (it's a safety measure to prevent the second nut from turning, so you won't be able to turn that special washer EVER). THEN you will have access to the second spindle nut. Also, there is a spindle nut socket for these nuts, i hope you're using it (mallet + chisel = destroyed useless spindle nut).
Here they sell the socket: http://shop.advanceautoparts.com/web...U_T|GRP2062___
P.S.: I'll have your broken truck for $100
Old 11-25-2011, 05:31 PM
davidsnook1981
Removed the first nut then a couple of washers. Now there is a nut exactly like the first one that will not move. i can see the wheel bearing directly behind that second nut. well...whats left of the bearing anyway.
Old 11-25-2011, 05:32 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
I assumed he already had the keeper out otherwise he wouldn't be able to get his socket on the nut!
Old 11-25-2011, 05:33 PM
davidsnook1981
And i am using the correct tool. 2.5 inch diameter socket with 4 fingers
Old 11-25-2011, 05:34 PM
davidsnook1981
Maybe not exactyly 2.5 inch but close anyway
Old 11-25-2011, 05:35 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
if it got the first one off then the answer is yes and a destroyed inner nut...back to hammer and chisel.
Old 11-25-2011, 05:36 PM
bashby's Avatar
bashby
bashby is offline
A BIG hammer and punch or chisel.. try to cut it or break it. What tools do you have? Dremel with a cutoff wheel might get in there to cut it.
Quick Reply: Problem removing stuck inner spindle nut
