2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
k&n filter vibration?
Old 12-30-2011, 12:41 PM
thefnswits's Avatar
thefnswits
thefnswits is offline
Alright s I just instaled the k&n air intake ad it sounsmean except I get a wicked dash rattle frm acoustic vibrations around 3200 rpm to 3500. Any ideas?
Old 12-31-2011, 12:25 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
normal
that intake is worthless btw. I'd remove and return it for your $$$ back. Then take the $$$ and buy a SCT tuner and get custom tunes.
You'll get better performance and no annoying buzz or harmonics at certain rpm's
Old 12-31-2011, 07:23 AM
thefnswits's Avatar
thefnswits
I know you and mcdavis are intake haters...any reason why? I highly doubt anyone has ever put their expo on a dyno.
And I keep reading abou you guys saying "custom tune", what's so custom about it? I am interested in the tuner, just want more details. Thanks an happy new years!
Old 12-31-2011, 11:17 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I'm not a CAI hater. I ran one on my 06 F-150 (Volant). It made great noises, but nothing performance wise. I finally strapped a blower on there for real giddy-up
I ran one on my 09 Mustang Bullitt...now that was good for +15 HP with factory tune...and over 30 RWHP paired with long tubes and full offroad exhaust.
You are only going to see 3-5 HP on a good day from a CAI on a 6,000 lbs vehicle. Tuning might get you closer to 10 HP gain.
As far as tuning, most of the "Custom" tunes you buy are canned. The tuner takes a know profile that makes good power, tweaks it to your octane and location and sends it to you. I've had great success with those using my Mustang because a dyno wasn't available where I live
Once you have the tune installed, you can data log. Send that back to the tuner and they can tweak things in to give you a truly custom tune
Old 12-31-2011, 11:46 AM
thefnswits's Avatar
thefnswits
It was only 215 bucks and it sounds like a beast. I'm hapyy with that. Any advice on a exhaust or an aftermarket MAF? Who should I talk to at sct? Finally, can I get a tune for 87 octane? I don't really need to spend more on gas...thanks!
Old 12-31-2011, 05:56 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
It's only about $5 more per tank to run 91-93 octane vice 87 octane. That's a pack of cigarettes or a Starbucks.
You can get a 87 octane tune. Pointless in my eyes as its essentially a transmission only tune. You're going to spend $300-$400 on a tuner and tuning, what's another $5 each tankfull?
Old 01-02-2012, 03:31 AM
f150dave2002's Avatar
f150dave2002
f150dave2002 is offline
Its probably where the intake comes in through the "cold air" shield. Mine rattled there. The fix I made was to get some black fuel line hose and split it length wise and put it around the opening where the plastic air line connects to the filter. If this isn't it, make sure all your radiator clamps are tight. Drive for a while and then check for shiny spots where something is vibrating against. Or with the engine running and the hood open, pull your throttle cable and see if you can pin point the rattle.
Hope this helps, PM me or I'll check back if this works for you. Otherwise my late night coffee induced rambling should get a picture to help say what my words may be missing.
Old 01-02-2012, 08:39 AM
thefnswits's Avatar
thefnswits
thanks for the info. the rattle in mine seems to come from the dash, inside the cab. it only does it under full throttle. rest of the time it sounds good.
Old 01-02-2012, 10:39 AM
berry1234's Avatar
berry1234
berry1234 is offline
Is the rest of your truck stock? Exhaust? The funky shape of the OEM intake is because it stops odd harmonics similar to what you are hearing. The K and N is more than likely creating resonance and that is vibrating the dash plastic. The dash is known for rattles, etc. If you can recreate the rattle without blowing up your engine while parked you might be able to locate it and then add foam/felt tape/etc. to eliminate it.
TXGold76
2017+ Super Duty
03-10-2017 02:33 PM
calimove
2004 - 2008 F150
04-27-2009 11:46 AM
fordtruckman
2004 - 2008 F150
02-20-2008 09:25 PM
motordude0616
04-05-2006 01:41 PM
DeckedoutF150
Computer Chips & Tuners
09-02-2004 09:02 PM
Quick Reply: k&n filter vibration?
