460 timing boost
460 timing boost
Well I finally got the problems worked out on my 94 460 engine swap. In celebration I was going to move up the timing a few degrees to try and push a little more out of the old horse. Is this a worth-while endeavor? Where should I move it to? Its a 460 bored .030 and has an rv cam and headers, stock intake with no horns. Also no pcv valve or smog pump. Any suggestions? Thanks for the help.
With the factory setting being 10 degrees some have had great results bumping it up to 12 to 16 degrees.. It is dependent on the particular engine and set up, I would try about 12 to start with and if all goes well go to 14 or so and see if it does ok there (as in no pinging)
The increase does help with power and some say it helps with mileage..
the ping comes under load. full throttle, low rpm while in gear is the best way to check for it (if you have a manual). if it pings just back it off a hair. you can keep pushin it until it pings if you do it carefully, in small increments, testing between each adjustment.
if you have no pcv valve, did you add a breather?
I use this method with its time saving ease, and good results...ignore the carb talk, and don't forget the spout.
Vacuum Engine Timing | MILEPOSTS Garage (Tech Tips)
You should never hear any pinging at idle or revving it. Ping, if any, would occur under load. That is why you have to experiment with what your combination will work with.
E30tdf
09-30-2006 05:54 PM
Big O Dave
11-26-2005 08:40 PM
RubberDuck
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
06-20-2005 12:54 PM
