What should timing be set to run WVO
Old 11-15-2011, 02:36 PM
curbill4's Avatar
curbill4
curbill4 is offline
On a 1993 7.3 non-turbo Auto is there any special setting that my injector pump be set for? I have a little over 100,000 miles running wvo on 4 mercedes 5 cyl diesels. I centrifuge my oil and dewater it. It goes thru a 1 micron sock and I now see less fat in my filters. I have 2 tanks in this ford and heat on both. I presently run a 50/50 blend in the ford. My IP just crapped out and a rebuilt was installed. I have a mechanic who is set-up to time the engine with a pheret timing adapter. I just wonder if I should have a different setting than what ford calls for. The engine has less than 10,000 miles since a complete rebuild. The prior owner did not believe in oil changes. I am in So Fl and we do not get temps below 40 degrees. If it gets that cold I just wait till the sun comes up to start the benz's. Thank you.
Old 11-17-2011, 12:45 PM
eatont9999's Avatar
eatont9999
eatont9999 is offline
With all the reading I have done, people seem to suggest advancing the timing a small amount for adding a turbo or running thicker fuel/WMO/WVO. I'm no expert and I haven't had the time to do proper testing but I plan on 10-11 degrees BTDC when I install my turbo and start running WMO. The logic behind the advancement is the increased cylinder pressure with a turbo can retard the injection of fuel. I would guess something similar is happening when running fuel other than #2.
eatont9999
03-13-2012 04:38 PM
that-1redneck
12-21-2011 08:16 AM
wreckinball
20
02-18-2011 11:09 AM
f350idi
12-22-2010 05:54 PM
ct500lt
4 Cylinder Engines
11-24-2004 06:54 PM
Quick Reply: What should timing be set to run WVO
