Project: Smogie...RacinNdrummins IDI build
Old 08-23-2014, 06:12 AM
85F350IDI's Avatar
85F350IDI
85F350IDI is offline
I would love to get this kit when I have the money haha, this is one hell of a build, can't wait for it to be finished, seems like it'll be one mean IDI
  #1997
Old 08-23-2014, 06:09 PM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Got the top end off my engine...
I am never running Fel-Pro Head gaskets again. When it lifted the heads, it burned the gasket material behind the firering and left it unsupported. The front cylinder burned through, but the back cylinder firering was still intact, just stretched beyond belief. The passenger side had water in the back cylinder, but the gasket was still intact. The drivers side speaks for itself.
I also compared a 7.3 gasket side by side with the 6.9 and tried it on the block, the 7.3 gasket will work fine on the 6.9 block, and is less swiss-cheese-like. I ordered up a set of 7.3 Victor-Reinz gaskets to go with the 9/16 studs and O-rings...
  #1998
Old 08-23-2014, 08:26 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Boy that sucks. Just not made like they use to be I guess.
  #1999
Old 08-23-2014, 08:34 PM
bashby's Avatar
bashby
bashby is offline
Anyone make a mls hg for this?
  #2000
Old 08-23-2014, 09:17 PM
Ford F834's Avatar
Ford F834
Ford F834 is offline
Once again... Thanks for the vicarious learning lesson... that's some great information in that post.
  #2001
Old 08-23-2014, 09:31 PM
RacinNdrummin
No, but if these Victors don't do the job with about 300cc of fuel, I will have them made and supply them.
  #2002
Old 08-23-2014, 09:33 PM
RacinNdrummin
Exactly Jonathan, by the time your truck is on the road, you should have a bulletproof setup!
  #2003
Old 08-23-2014, 09:36 PM
RacinNdrummin
Another side note I just noticed while looking at the pics.... The gasket blew in the two most unsupported spots on the deck. I'd say that proves it was a lifted head...
  #2004
Old 08-24-2014, 02:19 AM
85F350IDI's Avatar
85F350IDI
I'm confused as to where the exhaust goes,I can't tell if it goes into the the back of the turbo or not haha
  #2005
Old 08-26-2014, 12:54 PM
David85's Avatar
David85
David85 is offline
subscribing.....
  #2006
Old 08-31-2014, 09:54 PM
RacinNdrummin
Little Bit of an Update time.
I pre-cursor it by saying that the new R&D turbo kit works beautifully. We got it all together on Keith's truck. He was seeing 12psi non-IC on an early banks before (The turbo was on its way out), WOT. Without any tuning, we were seeing 18psi intercooled, and as soon as it got there, it was obliterating the clutch. Drive pressure was 30-31psi (a little high and wastegate limited), has a ton more low-midrange, and EGT's are 200* lower at cruise. Obviously most of that is do to the HX35, but having an efficient hotside doesn't hurt. He has a new southbend coming in this week (His current clutch is a valair 300hp unit), and is heading to alligator performances dyno in a couple of weeks, so the goal is to get it all tuned in by then so he can lay down some decent numbers.
Now back to Smogie...
I posted over at CompetitionDiesel just to get some reassurance on where I should go turbo wise. Those guys seem as unsure as me even after running the numbers, so its looking like I may have to just try some stuff out and go from there. The link is the following just in case anybody wants to read the details...
Help Checking my numbers, and a bit of Direction... - Competition Diesel.Com - Bringing The BEST Together
Also found out this week that I will have to have a new Pump Cam made, nobody wants to regrind the LR cam out of the pump. So I am in the process of drawing a new one up in cad. It will use the stock pump gear that I will modify to make adjustable, as well as the stock timing cover.
More soon...
  #2007
Old 09-01-2014, 08:11 AM
88 Ford IDI's Avatar
88 Ford IDI
88 Ford IDI is offline
Is there ever a possibility of you producing a kit to help people bolt on an inline IP on? Like you could produce the intake and pump gear and all that and the buyer would just have to get the pump. That could be a cool possibilty down the line. Especially since you are doing it, it would be easier to reproduce...
  #2008
Old 09-01-2014, 09:26 AM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
Right on Racin! Glad to hear it's coming along! Is Keith using that engine I sold him? I haven't heard from him at all after that so I hope it worked for him
  #2009
Old 09-01-2014, 11:18 AM
RacinNdrummin
I got some ideas floating around my head, they wont involve a P-Pump, but some other sort of inline pump, maybe an MW or A-pump, or even a modded V-pump. Those will put out plenty of fuel, more cost effective and more available.
  #2010
Old 09-01-2014, 11:20 AM
RacinNdrummin
Yeah, he rebuilt your old IDIT, that's what he is running.
Looks like the passenger side uppipe V-band wasn't fully seated, so might even see better numbers out if it as it sits as well.
Quick Reply: Project: Smogie...RacinNdrummins IDI build
