Power Brakes for 1960 Ford
I am new to the forum. I have a 1960 Ford F-100 with a 390 and C6 in it. I am interested in putting power brakes or at a minimum putting a dual master cylinder on it. Anyone have suggestion for swapping from a later model truck or buying a kit from manufacter? Thanks.
On mine I used a hydra-vac booster off a '59 f600. Works great and stops on a dime. I've been told that a booster/mastercylinder from a mid 70's Ford truck bolts right in but I've never actually compared them in person.
<a href="http://s940.photobucket.com/albums/ad248/AsphaltCowboy90/?action=view&current=IMG_1307.jpg" target="_blank"><img src="http://i940.photobucket.com/albums/ad248/AsphaltCowboy90/IMG_1307.jpg" border="0" alt="Photobucket"></a>
on
Excellent placement on the Hydra-Vac booster, not stock mounting point of course, but at least it's not in the way like the other up-grades that I've seen.
Thanks for the info.
Thank for the info. That is really a conversation piece I bet when you lift the hood.
Thanks for the info. I like your setup.
I bought a dual resevoir master cylinder for my 58F100 from Engineered Components 860-872-7046 and it works fine. As I recall its a late model Lincoln dual resevoir master cylinder and a seperate adapter(conversion) that allows one to bolt it to your firewall etc and use all your existing pedals etc.
Its a manual not power master cylinder etc. But I believe they offer power too.
Don't know if they still offer it, but it works fine for me. My only thought is that I think if I were doing it again--today etc-I'd go with power discs. I think the four wheels drums--for me--and high speed driving are not quite as good as I'd like and I might make an improvement some day.
They work as expected its just that my 58 goes pretty fast--some times-and it takes more time to slow it down that I really like.
My 48F1 with factory drums and a much smaller motor stops really good--but its lighter and not so fast. The faster/heavier truck needs more stopping power.
By the way, I like Ibuzzard's suggestion too. Just trying to add more options that's all.
Engineered Components, Inc. - Your One Stop Brake Shop!
I have this same kit, though have not installed it yet. The parts look nice, and the price was really right.
