99 4wd stopped working question
Ok I've done some searching and reading and really haven't found a answer. My 99 f250 sd 4x4 v10 with a automatic transmission stock hubs with ESOF. I checked the fuses under steering wheel. All good. Showing no error codes. Replaced vacuum lines. I've been driving it for some time only using the lock outs on the hub. Whats different is there is no light on dash stating 2wd, 4wd or low. And when manually locked they don't move in snow. new hubs? I don't really care about switching with ESOF I just need 4WD for plowing!
ANY tips will be well appreciated. Thanks
Somewhere on here there's a sort of troubleshooting manual for the ESOF system, for the life of me I can't find it though. Do a search though and maybe you'll run across it or piece enought together to figure it out. I've got the old simple manual system so I don't know a whole lot about the ESOF, but I'm thinking if your dash lights aren't working, then the shift motor on the transfer case isn't sending the signal to the light, which could mean it's bad or it's a problem further up the line. I think your truck has a GEM module which controls that, could also be your dash switch.
In answer to your question though, those relays are under the hood, they've changed locations around between they years but look for a covered box under the hood. Your owners manual will tell you what to look for.
Here is a link to my transfer case shift diagnostic. Since you have a 99 and I have an 04, none of the fuse numbers will match, and I will refer to a 4WD control module where you will have a GEM module. Otherwise it is the same.
When checking fuses, check anything in your Owner's Manual that refers to the GEM module or any "feed" (Run/Start feed, etc.) Check them with a test light. Never rely on a visual check. I believe in a '99 the shift motor relays are in a box next to the Power Distribution Box under the hood.
https://www.ford-trucks.com/forums/1...l#post10605244
Pulled motor apart. Had to cut due to seized torks screws. I knew it was shot so saved time and used a sawsall.
Little gears shattered during removal.
Far right is the plastic part of motor I think this part tells GEM that its in 4w 2w or low. Also must run light on dash as well.
The culprit. Looks like this is where it was broken.
(Top finger) shaft spins free when (bottom finger) motor isn't moving.
How I tested it while mounted on truck then after I removed it.
When I was running through diagnosing things the motor would run. Which fooled me for a bit........
HOPE THIS HELPS. Glad I didn't go throwing parts at it.
RyanMiller
08-17-2004 05:59 PM
