Modular V10 (6.8l)
4wd is not working
Old Aug 16, 2009 | 03:23 PM
AKtruck's Avatar
AKtruck
4wd is not working
I have on 01 f350 v10 and the 4wd will not engage. I turn the switch and the light does not come on. Any ideas about where I should start. Okay, now a dumb question, if I lock the hubs will the 4wd work then?
Old Aug 16, 2009 | 07:16 PM
Deluxe05's Avatar
Deluxe05
There is a chance that it will work if you manually lock in the auto-hubs. If it does work, it is a problem with the vacuum system that engages the hubs when they are in the "Auto" position.
Do a bit of searching--especially in the Super Duty forum--and you will find plenty of threads regarding the ESOF system.
Old Aug 16, 2009 | 09:09 PM
now05EX's Avatar
now05EX
check the fuse on the 4wd, if it is ok than it is probably the motor that engages the 4wd in the transfer case. The hubs only lock the front axle after the transfer case is engaged and the light indicates that engagement.
