You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
HELP!!! Swapping a 2004 Saleen sc281 into a 2005 F150 4.6l
Here is the story. Friend of mine totaled out his 2004 SC281 has 11k miles on it. I want to pull the motor and put it in my f150. The sc281 was a 5sp car my truck is an auto. I want to keep the auto if possible. What issues do you think im am going to have doing this swap? I know i will prob need a tune. but the physical and electrical should be no different Right
This SC281 is a supercharged 4.6? 2 valve?
If so it should go right in and bolt to your auto trany.
You will need tuning and probably a better fuel pump,MAF.The injectors should be with it.
Now that I think about it,the car motor is most likely a 3Valve. But I believe it can be tuned to run properly.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
So it is not a supercharged motor? SC281/ s281
If not it will bolt right in but will be better to swap the truck intake-manifold onto it!
__________________
OK,,so it is supercharged...lol I thought so.
No, you will have to fab up or rig an inlet for the opposite side.Since it is setup different then you pickup truck.
But that shouldn't be much trouble for ya.
__________________
