Transmission Problem Mazda 5 speed
When I back up and push the clutch in rear wheels lock up.
Took top off transmission and forks were worn. replaced with top from junk yard still have the same problem. Gears look great in Tranmission. Put in new clutch, flywheel and trans top with used forks still has the same problem.
When it first happen I was able to drive home just using 1st and 3rd gear. Now I have all the gears but it grinds when I shift to 2nd and will lock up when I back up. Stumped in FL.
1991 F150 4.9 124,000 miles 2 wheel drive
Old Kentucky Shooter
10-27-2010 07:52 PM
mdjohnson
02-14-2006 02:47 PM
mochiba
01-13-2001 11:45 PM
150, 1996, 5speed, f150, ford, mazda, problem, problems, slipping, speed, trans, transition, transmission, troubleshooting, truck
