smokin dipstick(not THAT one)
I was bored one day and took mine apart after cleaning it with gas.
Cleaned it again in gas in a pan and still got oil out of it.
The vapors from the crank case gather in the filter and clog it up.
No real way past it, thats why you get oil in your intake boot.
When its clean, the turbo will pull the vapors out of the crank case and will stop the dipstick tube smoke.
I got mine vented to atmo right now, so its a lot better, but i'll still get smoke out the tube if I pull the dipstick while its running.
I've actually had mine clog enough to pop the dipstick tube out.
I was cleaning it once a month before I vented to atmo, now it just forces the gas out naturally instead of pulling them from the motor.
Stays a lot cleaner.
I don't suggest pulling yours apart though, its more of a pita than anything.
But if you clean it, use a bucket and soak it good.
It will make some good 2 cycle fuel. haha.
(dont use it though in a 2cycle motor please)
If you go to do the dipstick fix be carefull in that the reciever end peice can fall inside the pan if your not carefull.
In this post thats what he used the needle nose vise grips for holding that in place.
https://www.ford-trucks.com/forums/7...-be-fixed.html
just fixed mine the other day. took the CCV out blowed into it and it feels no resistance, so did not do a gasline clean. started the engine. while watching the smoke goes straing up out of the dipstick hole and the filler openning, put my hand over the intake partially blocked it to generate vaccum. smoke stopped immediately. Put everyting back together, making sure so vacum leak at all the junctions. No more smike in the cab now. I guess that mine has a vaccum leak. Erwin
It's really half assed.
It would work better if properly done, but I'd rather not pull oil gasses into my turbo and oil that up. What a mess it makes!
You can pull a stronger vacuum from the exhaust when done properly.
Thats my long term plan, but I have not got there yet.
Collision
05-12-2016 01:01 PM
63' f100
18
03-13-2013 10:54 PM
jdecker88
38
09-17-2008 10:47 AM
