how to remove the 'change oil soon' message
Old 11-06-2011, 09:41 AM
jeffdoerr's Avatar
jeffdoerr
jeffdoerr is offline
I am on top of my oil changes, but this is the first time I have seen the center display flash "change oil soon" and stay on until you hit the OK button. I went through the manual and I cannot find where there is a provision to clear the message. The oil was just changed, has maybe 600 miles on it.
help
2011 F150 EB lariat with 10,000 on it
Old 11-06-2011, 10:20 AM
tex25025's Avatar
tex25025
tex25025 is offline
help
I haven't gotten the new enhancement license for my 2010 yet for AutoEnginuity, however, I do know on the Lexus vehicles that my parents I have, I can program it not to show that message and/or have the light come on.
I didn't keep it off entirely for the one that my dad drives as he won't get it serviced in time if he doesn't have an annoying reminder like that always on telling him to get it taken care of, but it will keep it off on the Lexus.
Although, bare in mind that is with the Lexus, I have not been able to try that with my 2010 Ford, so there may not be the same functionality between the two.
Old 11-06-2011, 03:21 PM
adamsre's Avatar
adamsre
adamsre is offline
You have the LCD screen correct? If you do go to oil life and reset to %100.
Old 11-06-2011, 03:35 PM
vans's Avatar
vans
vans is offline
Adamsre is correct
go to settings
scroll down to vehicle
scroll to oil life reset
note you can set oil life to a number of diferent percentages
I did my first oil change at 1400 miles, set oil life to 50%
I plan to change oil every 3300 miles
Old 11-06-2011, 04:21 PM
ebexp94's Avatar
ebexp94
ebexp94 is offline
I never reset my oil life when I changed it at 3,750 miles. At 8,100 now and the truck hasn't complained yet.
Old 11-06-2011, 05:11 PM
tex25025's Avatar
tex25025
tex25025 is offline
That won't disable it if I remember correctly. That'll just give you a respite until it hits it's min. % threshold again.
Old 11-06-2011, 05:54 PM
jeffdoerr's Avatar
jeffdoerr
I finally found the reset menu.
Old 11-06-2011, 07:32 PM
adamsre's Avatar
adamsre
adamsre is offline
He did not ask to disable it, just reset/clear the message. This is the step taken everytime you change the oil. It's all in the little thing called the owner's manual.
Old 11-06-2011, 08:20 PM
tex25025's Avatar
tex25025
tex25025 is offline
I guess I was a little confused with the term "remove" in the title as that could have gone either way as far as to disable or to reset/clear. Although he did use the term clear in the body, I guess I was just hung up on the remove portion.
Plus I was also hung up with disabling things after just discovering my 150 picked up text messaging on my new phone.
Old 11-06-2011, 08:56 PM
wwilson43's Avatar
wwilson43
wwilson43 is offline
I was told by the service that you can reset the milage to what you want it for, if you change every 5000 miles you can set for that.
NarrowGate
2017+ Super Duty
21
10-23-2017 09:34 PM
egregg57
6.7L Power Stroke Diesel
08-15-2016 02:36 PM
KPT
06-13-2013 07:27 AM
640 CI Aluminum FORD
2009 - 2014 F150
03-13-2012 10:06 PM
blueheron
05-24-2011 08:33 PM
Quick Reply: how to remove the 'change oil soon' message
