Must be the Season, My 1999 F-350 same problem. I had it towed home Fuse 30 was blown and I replaced it, still did not start. This morning I went out it started, Pulled out the scanner, toss out a code that the memory was not stored but as I had the Batteries disconnected this was not a worry. It shut its self off and back to a No start condition I put the battery charger on it, just to top off the batteries. I have check all fuses again, Replaced the CPS Sensor, Ideas???? any help would be appreciated greatly, and would earn dinner drinks and a great cigar to anyone who could help me...
Is the WTS working properly now?
Try swapping the IDM relay with the A/C Blower relay. It is a quick way to check the IDM relay for fault. If it starts, and now blower acts up, you found your culprit.
Thank you Roland Yes I did swap the relays. No change
