Trying to make my 6.0 PSD reliable..did I do it correctly?
Are your guys prices paying a shop or dealership, or DIY work? My thought is that most of the extremely high amounts of money that is spent on these trucks goes to pay for labor, not having to pay for the cost of the labor I would assume would drop the cost significantly?
I get asked this question from time to time. Would you buy that 6.0L powered truck again given the chance for a "do over"? To which I reply, your darn skippy I'd sign on the dotted line again. Yes, they're expensive to maintain and their fuel is at a higher cost. But when I can pull our 9500# 5th wheel down the interstate at 70mph and get 12mpg while facing a head wind...there ain't a gas engine out there that can do that. Even after 104k miles of ownership I still enjoy the truck...just not the fuel price.
I wouldn't just start replacing the EGR simply because you got a code. Why do so many people recommend it and/or even listen to advice like that? What does your mechanic say? Post up your MAF, MAP readings and EBP or something. Someone is bound to be able to help you. Don't just replace the EGR.
Do you have the ScanGauge II? It will help you tremendously. Worth its weight in gold.
A neglected EGR valve will have excessive amounts of carbon buildup. I've seen photos of some really bad ones. People without EGR valves (the delete) get that code, so it can't possibly be just an EGR valve issue. I think you should look into it more and verify different readings. I hope the experts jump in here soon. Changing parts can get really expensive. When he cleaned your EGR valve, did he replace the o-rings? What did he clean it with? Did he know that he wasn't supposed to submerge it past a certain point or he'd damage the internals? Also the MAF, EBP, MAP you need to post those readings. I am sure they are all related, just need an expert to guide you along.
EGR valve cleaning with pics...
Another EGR Valve cleaning w/pics - Ford Powerstroke Diesel Forum
and this...
Learning to Live with Your Powerstroke 6.0L EGR
and this...
Brett's 6.0
1999 to 2016 Super Duty
11-13-2010 08:40 PM
