changing glow plugs, need help (early 99)
I am in the process of changing my glow plugs on an early 99. I need some torque specs. I had to loosen the rockers to remove the old plugs. I need the torque specs on the rocker bolts... there are two bolts per rocker. They are 8mm bolts. I was able to find that the plugs themselves are 14lbs and valve covers are 8lbs. Any help or advice towards reassembly is greatly appreciated!
Here you go info and pics on how to do it. Might as well while your in there anyway. Save yourself some trouble down the road. Read the thread and will have a link to pics ect. courtesy of the other brothers.
https://www.ford-trucks.com/forums/1...t=.50+cent+mod
Now that I read that I'm thinking about doing spark plugs on some of my old cars without a spark plug socket and I have a piece of tubing just for that in my tool box. Well I'm all ready to reinstall valve covers. I had 5 bad plugs and I did the fifty cent mod (the clips were identical to factory). My factory harness was hanging off about an eighth inch on passenger side so I wonder if that's why I occasionally have a rough idle?
slim613
44
08-27-2011 06:03 PM
amthatiam
05-06-2010 12:20 PM
