starting issue
Old 10-29-2011, 01:33 PM
mstiles19's Avatar
mstiles19
mstiles19 is offline
starting issue
Over the past few weeks my truck has been difficult to start, but it would eventually start. This would only happen on the mornings when it was colder. This morning it just wont start. (it is the coldest it has been) It turns over but just does not start. Also it does not throw any codes.
Any ideas on what could be causing this? I am at a total loss as to what the problem is. its not the IAC i replaced it not to long ago and i just got done taking it off and cleaning it.
my truck is a 2001 5.4 l gas just hit 199,900 miles
Old 10-29-2011, 03:17 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I would suspect either the fuel pressure regulator or pump assembly allowing the fuel to drain back to the tank.
I would test the fuel pressure at cold start-up. It should come up to around 40-42psi when you turn the key on after a second or two.
If you don't have access to a gauge, you can try to turn the key to run for about 2 seconds, then turning it back off 5 or 6 times, then try to start it and see if it starts right up. If so, then you have a bad check valve in either the regulator or the fuel pump assembly.
Old 10-29-2011, 04:32 PM
mstiles19's Avatar
mstiles19
ok thanks, just tried cycling it like you said and it didnt start, could that mean the pump is completely shot?
thanks
Old 10-29-2011, 04:33 PM
mstiles19's Avatar
mstiles19
also dont know if it would have an effect but looking back it seems that the only time i had trouble starting was when i parked on a slope with the front of the truck uphill
Old 10-29-2011, 08:26 PM
mstiles19's Avatar
mstiles19
any one else have any ideas? is there any way to check the fuel pump?
also i sprayed some ether to try to get it to kick over and it didnt even crackle, so that makes me think it is something else.
thanks
Banjo250
1997 - 2003 F150
18
07-02-2019 04:29 PM
gotdurt
Modular V8 (4.6L, 5.4L)
10-29-2017 12:26 PM
Mbp002
2009 - 2014 F150
04-16-2017 12:59 AM
jesterdog
01-30-2009 11:30 AM
mwittman
1983 - 2012 Ranger & B-Series
11-28-2001 02:33 PM
Quick Reply: starting issue
