E4OD Transmission Problem!
#62
#63
on
Well I thought that I had fixed it, then the wife said when she was driving it she hit some pothole and the tach went out and it went into limp mode. Obviously there is a bad electrical connection somewhere... I just have to find it.
Unless anyone else has any advice?
we're way off from the original question of this thread though.it would be best to start new threads for new questions.
#65
Got stuck in mud 95 f150 stalls when put in D now
Hey guys. I need your help pls. I have E4OD trans. It stalls at red lights and when put in D. I changed filter and fluid. (Filter came out w pan) no change. Found stripped wires on shift connector like pic in this thread. Waiting on part now. Don't think it will fix my problem though! What should I be looking at? Solenoid pack? Tcc? Tc?
#66
#67
Hey mark. Thanks for speedy reply!!! Codes are; 638-temp sensor
558-egr valve regulator
621-shift solenoid 1
622- shift solenoid 2
629-converter clutch solenoid
626- coast clutch solenoid
624- electronic pressure control solenoid
452- vehicle speed sensor
33w- insufficient egr flow detected
#68
332- insufficient egr flow detected
#69
#70
I am aware. I have an E4OD transmission and mark seems to know a lot about them. So I posted here.
#71
#72
I did start a thread in the 87-96 f-150 forum b4 replying here.
Ok. That's what I thought. I've already ordered a replacement and also a clip for the filter just to be on the safe side. Harness should be here today. I'll let u know how it goes.
Do u have any tips on accurately reading the trans dipstick? Not sure if it's the same on all AT, but on one side the fluid is all over. And on the other it looks like I can get a close to accurate reading. Am I going off the one side?
#73
#75
