Q: 1988 Dual Tank Fuel Pumps Operation
Old 10-26-2011, 03:49 PM
quisp's Avatar
quisp
quisp is offline
1988 F150 Lariat SB 5.0 EFI Dual Tanks.I have the "Low pressure pumps" in both the Rear, and Side tanks, and a Hi-Pressure Pump" on my frame rail- Now, I Understand that I have a "Fuel Resevoir " of sorts that holds un-used fuel that was sent to the Fuel rail,Does anyone know much about this system, ?? I believe I have some contamination in the rear Tank, It has about eight gallons of gas in there, -when the motor begins to sputter, I switch it to the Front tank, and it straightens out, stops sputtering, and poppin'Switch it back to the rear tank, and within a couple of minutes, it starts sputtering agin. Then I click it back to the front to keep it from dyin.I dont use the front tank much because it has a leak, But for some reason, after a couple of days or so of driving, It seems to accumulate Fuel..?Is this the Fuel being sent back to the Fuel resevoir, and back into a Tank?Because It seems that whatever is in the rear tank, is slowly making its way into the front tank, possibly from this By-pass to the Fuel Resevoir?Can anyone clarify this for me? Thanks
Old 10-26-2011, 03:59 PM
mpc07005's Avatar
mpc07005
mpc07005 is offline
That "fuel reservoir" Is also called the 6 port reservoir switching valve. It is before the High pressure pump, and has 2 lines to each tank and 2 to the engine, 1 supply and 1 return each. When that Valve fails, you get 'cross flow' which is mostly return to the wrong tank, but can be pumped in from the other tank. Check the wiring to the rear sender (low pressure), and if you think the rear tank is contaminated, get that gas out. The cross flow means you need a new selector valve, but if you have no intention of using the midship tank, you can bypass it.
-Mike
Old 10-26-2011, 04:07 PM
quisp's Avatar
quisp
quisp is offline
I see how this works, -thanks mike, -gotta get the bad gas out.
Iraa
03-01-2019 03:17 PM
Big350
11-11-2013 11:31 AM
palletcutter
35
03-02-2012 05:51 AM
fordsuperduty250
09-20-2011 01:04 PM
jtm8571
07-28-2009 12:00 AM
Quick Reply: Q: 1988 Dual Tank Fuel Pumps Operation
