Blend door actuator- Defrost issue
Old 10-25-2011, 08:57 PM
dilas's Avatar
dilas
dilas is online now
Posted this not long ago, but no replies. So I'm going to change this thread a bit.
This is becoming an issue with colder weather peeking in with this defrost issue, I'm only able to use vent to heat or cool. Not able to use the defrost or floor switch. Thanks to this forum, apparently it's the blend door actuator.
Called the dealer and they wanted $800 to replace the blend door actuator. Gee! They said it's labor intensed, also said probably foam is stuck, and actuator part might not be needed. If I decided to go with dealer to do it, should I have them replace actuator anyway since they are prone with problems in this generation?
Has any one of you done the work on it, if so how was it? I'm hoping doing it myself, should I invest a good manual for it? Which manual is recommended?
Old 10-26-2011, 05:15 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
Dilas the work has been done. There is a way to get to the side of the blend door through the driver's side footwell area. I'm surfing via my phone right now, otherwise I'd run a search for you. There is a thread or two detailing how to get in to reach the door.
Old 10-26-2011, 12:25 PM
Rudeman's Avatar
Rudeman
Rudeman is offline
Did the job on my wife's Windstar and it was pretty easy. The biggest issue was the cramped quarters. I got the best price for the actuator on Amazon.
Old 10-26-2011, 08:57 PM
dilas's Avatar
dilas
dilas is online now
You meant this thread?
https://www.ford-trucks.com/forums/8...procedure.html
Seems like it's on passenger side instead of driver's?
Old 10-27-2011, 06:51 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
You got it!
Now lets just hope that I didn't do all of my jobs yesterday from the wrong side...
Tyler Heleine
6.4L Power Stroke Diesel
04-17-2014 10:31 PM
ScottInTexas
1997 - 2003 F150
12-25-2008 06:46 PM
Ford43
Escape & Escape Hybrid
11-24-2007 08:46 PM
skysurfer2010
1997-2006 Expedition & Navigator
12-07-2005 04:51 AM
cj4dom
12-19-2004 01:53 PM
Quick Reply: Blend door actuator- Defrost issue
