Old 11-11-2014, 07:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Excursion Lift Kits / Which One?
Old 12-16-2011, 12:20 AM
7.3mongo's Avatar
7.3mongo
7.3mongo is offline
Originally Posted by Robuilt
so just for clarity, i can run any leaf spring lift kit from a F252/350 on a 4x4 excursion?
newbie question, i know, but i found it on a search thread if that helps, lol
Yes you can. an excursion is an f250 frame with a soft rated spring (like a lowering spring)
Old 12-16-2011, 12:21 AM
7.3mongo's Avatar
7.3mongo
7.3mongo is offline
Originally Posted by medina525x
I thought there was someone on here who successfully installed
a 5" lift and is runnin 37's but I'm not sure what thread I saw it in.
I do remember it was a greyish-blue excursion with 37'' Kumho's. Anyhow I'm kinda leaning
toward the Procomp 6'' kit with the fox reservoir shocks. The tech at 4wheelparts
told me that the procomp 6'' kit actually nets 5'' after the install
im running 37" with about 5" no rubbing no problems
Old 12-16-2011, 12:30 AM
Robuilt's Avatar
Robuilt
Robuilt is offline
Thanks Mongo. I actually have a notebook where i write down all these facts and "build" my vehicle (or in my case, my upcoming purchase)
Old 12-16-2011, 12:37 AM
7.3mongo's Avatar
7.3mongo
7.3mongo is offline
no problem. i do the same thing. i have one full of part numbers
Old 12-16-2011, 12:42 AM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
My excursion frame wasn't close to the same frame as my F350, but the suspension was exactly the same
Old 12-16-2011, 06:45 AM
7.3mongo's Avatar
7.3mongo
7.3mongo is offline
Are you sure? My 02 X is just like my 99 F350....that and all the other I have worked on
Old 12-16-2011, 07:17 AM
Red Ex's Avatar
Red Ex
Red Ex is offline
The frame is different in the rear. The F250 frame goes straight out the back but the X frame turns down in the back. Same springs for 99-04.
Old 12-16-2011, 12:30 PM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
yip...the excursion frame rails are straight from the front shackle to the rear spring hanger, where the F350 wasnt....it dipped down in the middle under the cab.
I tried to find some pics in my build thread, but i didnt see any....but my F350 was a regular cab...maybe the super and crew cabs are different
Old 12-16-2011, 12:47 PM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
Excursions dont have these curves
see the curved section by the gas tank.....excursion frames are straight from the front axle to the rear spring hanger
Old 12-17-2011, 09:23 AM
tjblair's Avatar
tjblair
tjblair is offline
Originally Posted by gotgig
If you decide to go with a 4" lift you might want to check BDS. I have the BDS 4" all spring lift and like it a lot. I'm running 35s on 18" wheels.....
Agreed, you can't beat BDS's ride quality, or warranty. IMO
Old 01-29-2012, 06:05 PM
Xv10's Avatar
Xv10
Xv10 is offline
Looking for feedback from you guys who have installed 4'' to 6'' of lift on your
leaf sprung X's. Ride quality, comfort and actual lift clearance are my
main objectives I'm looking for feed back on. Awesome site here and you
guys have some awesome trucks and X's. Any advice greatly appreciated
and thanks in advance.
2000 Ford Excursion 4x4
Priority Preferance & Goals
1. I want to run 37's with the minimal amount of lift.
2. If I go with a 4'' I want to run 35's on 18'' wheels.
3. If I go with a 6'' I want to run 37's on 18'' wheels.
I have a ProComp 4" lift and 35" tires on 20" rims. No trimming necessary.
Old 01-29-2012, 06:12 PM
Lowboy44's Avatar
Lowboy44
Lowboy44 is offline
This is a great thread to help newbies like me before I purchase a lift :-)
  #28
Old 01-29-2012, 06:29 PM
njneer1's Avatar
njneer1
njneer1 is offline
Dubbs,
What bars are in the second pic ?
  #29
Old 08-24-2012, 12:43 PM
x2k's Avatar
x2k
x2k is offline
First post here!!! Nice forum and very informative.
I'm contemplating on having my x2k xlt 4x4 lifted as well. Correct me if I'm wrong but when you lift a vehicle, won't the center of gravity go up as well? Will having a wider tire, stance offset the change of center of gravity? I'm worried about roll-overs when sudden turn situation arises.
  #30
Old 08-25-2013, 05:36 PM
sandman6's Avatar
sandman6
sandman6 is offline
frame change
dose anyone know if they changed the frame of the excursion or its suspension mounting points when they changed the fronts to coil overs in 2005?
I have a 2001 leaf system and found a 8" adjustable coil over lift off a decomisioned 2005 excursion diesel that did not pass the import inspection into Canada, that i want to install into the 2001 v10 4x4.
I don't want to be lured in by price only to pay double to modify everything else!
Quick Reply: Excursion Lift Kits / Which One?
