1977 f-100 302 v8 vacuum diagram
hello
74 with 302
some of mine are capped off i am not using stock breather but maybe someone here will know where they go if you are. i am not 100% sure mine are right i just know it works and runs good
back of carb to pcv
click images to enlarge
front bottom right of carb going to plastic t fitting then to distributor and to bottom of egr
click to enlarge
pass side bottom of carb to egr
click to enlarge
capped off
click to enlarge
now that i see your from california these pictures probably wont help with all the emissions stuff you probably have
74 with 302
back of carb to pcv
click to enlarge
click to enlarge
capped off
click to enlarge
I have a 1977 F100. 302, 2V 4 speed M/T. Manual brakes. Non CA truck. I do have a charcoal canister. I have the EGR carb plate, but the EGR hasn't been hooked up since I bought the pickup this spring. I don't have a ported vacuum switch on the drier's side rear manifold nor do I have a ported vacuum switch on the thermostat housing. I don't want to run my EGR, but I do want to operate the snorkel which is hooked up to manifold heat. Can I just tee off the distributor advance to run the air cleaner circuit. Thanks guys! Anyone have a diagram for my specific pickup? I can't find one anywhere.
Xtreasurehunter
08-27-2021 12:05 PM
kpc3my
11-28-2011 08:41 AM
Jeremy Ruppert
10-08-2009 07:21 AM
