1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Heater control valve
Old 10-21-2011, 01:57 PM
hodges710's Avatar
hodges710
hodges710 is offline
Where is the heater control valve at on a 1998 Expedition (4.6). thanks
Old 10-21-2011, 03:17 PM
pdqford's Avatar
pdqford
pdqford is offline
There's a heater control valve?
Old 10-21-2011, 04:29 PM
TerryB99's Avatar
TerryB99
TerryB99 is offline
I do not think most Ford's have one. I think coolant flows thru the heater core all the time.
Maybe better than having coolant just sit in the heater core all during warmer months
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
I don't believe there is a control valve per se. The engine coolant is always circulating throughout the system and the infamous blend door controls the heat or cooling you get in the cabin of the truck. I believe there is a vacuum operated valve on the F250's and Excursions, but not sure. You may have to repair the blend door and there are many posts regarding this.
Old 10-22-2011, 05:56 AM
hodges710's Avatar
hodges710
Thanks for the replies, I have found outt hat there is no HCV and I have already visualy inspected the blend door and it works good. I believe i am going to think i have a clogged heater core and/or line. thanks
Old 10-22-2011, 07:50 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
You might try reverse flushing the heater core to clear it. Have you ever used any kind of radiator stop leak stuff in your truck?
Old 10-22-2011, 08:32 AM
hodges710's Avatar
hodges710
no I have not use any kind of stuff like that, I will do the flushing and see what comes of it. With the rear unit, is there anything to do or should i flush the whole deal for the heat in rear is alittle warmer than front but nothing you would want to be in a long time in the winter in the new england area. thanks
Old 10-22-2011, 08:39 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
I would try flushing the whole system with plain water. I am not a fan of the corrosive radiator flush products as they can cause even bigger problems. It could be something as simple as a blockage at the hose connection at the engine or in the hose itself.
Old 10-22-2011, 08:52 AM
hodges710's Avatar
hodges710
Thanks
beartracks
08-24-2015 05:07 PM
MarauderV8
12-17-2014 01:44 PM
LastStarfighter
1983 - 2012 Ranger & B-Series
11-24-2012 03:22 PM
StevensPoint
06-24-2008 04:56 PM
fordx94
12-23-2004 09:55 PM
Quick Reply: Heater control valve
