How to get max MPG's
#31
Thanks for the replies. As usual the link led to more links and more reading. Have lots to learn.
I've seen a Wicked Wheel mentioned several times while reading. Is it an efficiency mod or power mod or is there a difference. I was originally looking a Banks.
Looks like DP is the tuner many are running. Do you have to have it customized or is there a generic?
Is anyone running Methonal / water injection?
Going to work on some fuel mods today and work on building a boost leak detector.
Man do I have a lot of work to do.
Paul
Paul
For clear answers on water/meth, you might want to talk to Joe (CSIPSD) on this site. He can have a bit of an attitude but knows what he's doing so be warned.
For boost leaks, don't forget the exhaust side. From the exhaust ports to the turbo, any signs of soot indicate leaks and can kill fuel economy and power.
For mods that work, look at our sigs and do some searches. It won't be long and you'll have a full blown case of PMS (Powerstroke Mod Syndrome).
#33
Plotted MPGs
My miles per gallon appears to be driven by seasonal conditions more than anything else. In the winter when driving through unplowed snow, and dealing with thick lubricants (not just motor oil, but also transmission fluid, gear lube in differentials, axle grease in hubs, etc) it takes more energy to move the truck and so mileage suffers. I've currently got chains on the rig and am keeping my speed to under 35mph...I imagine my next tank will be less than 10 mpg. Here is what the last 3.5 years MPG looks like plotted out,
The brown line is the actual MPG on the fill-up date for the previous tank and the blue line is the average miles per gallon of the previous 4 fill-ups.
Clearly, city driving and highway driving have different mileages, but both have trends that are driven by the seasons.
#34
- Air. I have the same 90-mile drive every work day (45 each way). It involves a road with city, hightway, flat, steep, uphill, downhill, cornering, and straight. I can have the same road conditions and driver behavior with no wind and the air is the only difference. I've noticed temperature and altitude have measurable impacts on my mileage. Closer to 60 or 70 degrees F seems to be the sweet spot for economy. Sea Level is very kind to the economy as well.
- Fuel. Winter mix is the norm shortly before the cold temps arrive. If they sell the winter mix too late, many diesel owners don't get the opportunity to burn off the summer fuel before it chills and gels. All that anti-gel kills the efficiency of the fuel.
#35
Just got my 2001 CC 4x4, Dont live far from you Paul. CUrrent mods are 4" exhaust, Banks muffler, Banks 6gun tuner (running on level 4), 4.56 gears, leveling kit, 37"BFG's. Best guess is I am getting 10.5 mpg based on just guage position. My Speedo is 7mph off, so my numbers are off a bit too, just havent had time to do the serious math yet.
Nice thread, I'm needin' more readin' for sure!
Really needing to get the 3.37's back! 2600 RPM @ 70mph.
EXTREMEFUN1300
12-21-2013 05:11 AM
Cuz-Pat
11-23-2004 09:37 PM
