Holley 1850 600CFM swap to 0-80452??
Gentlemen - new member here. As my name suggests I have a 79 F-350 4x4 (Dana 60's F/R). It has a 400M motor w/std trans. I'm thinking of swapping out the stumbling, misfiring holley 1850-9 with either a holley 0-80452 or maybe an edelbrock?? Intake is an edelbrock anyways so.. not sure if that means edelbrock carb would be bolt on or not. It's been a lonnnng time since I played with fuel systems. Any comments/suggestions would be appreciated! I do tow with it (albeit rarely) so the holley truck avenger is not an option Ideally I'd like to improve fuel economy with the same or slightly better performance from stock. Thanks!!
There should be a PN cast on the manifold... another way to tell is whether ya got an EGR valve.... sometimes EGRs behave badly and make it run rough.
Why not do a carb rebuild? It's easier to do and alot less costly than a $275 carb. Call it an investment in your Dentside and Holley education... gives ya street cred too.
One79one71
05-16-2017 08:06 PM
texanranger
04-25-2008 03:00 AM
podman152
07-15-2004 12:02 AM
BLaCkSiLo
28
03-05-2004 12:48 PM
