1985 F250 351w
Old 10-15-2011, 07:21 PM
jmmoore721's Avatar
jmmoore721
jmmoore721 is offline
Trailering
1985 F250 351w
Can you someone help me identify this? It came off of the right side of the motor where the Y-pipe fits to the exhaust.
Old 10-15-2011, 07:40 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,720 Likes on 1,391 Posts
Heat riser valve or a spacer to take the place of the heat riser valve.
Old 10-15-2011, 07:42 PM
jmmoore721's Avatar
jmmoore721
Trailering
Thanks.. can I get rid of this and just put a donut in its place? Neither of the holes where hooked up to anything..
Old 10-15-2011, 07:47 PM
Franklin2's Avatar
Franklin2
No, the y-pipe is not going to fit correctly. There is no ball area on the manifold for the y-pipe flare to fit correct? And it would end up being about 2 inches shorter without it also.
Old 10-15-2011, 08:00 PM
jmmoore721's Avatar
jmmoore721
Trailering
Thanks again. Do you know of any spacers or anything?
Old 10-16-2011, 08:17 AM
Franklin2's Avatar
Franklin2
What is the problem with what you have? Does it have some small holes that are leaking because someone took the valve out? If so, you can put bolts in them to plug them. If you have a friendly parts person, they may be able to find a spacer for you, or a whole manifold that didn't have the heat riser. I am not sure, but suspect there may be a factory setup that didn't have the heat riser system, but finding it in the parts book will take some time.
P.S. I think I know what the problem is; Is the mounting ear broke off in the picture?
Old 10-16-2011, 08:33 AM
Franklin2's Avatar
Franklin2
I just looked on Autozone's site, and they sell new Dorman exhaust manifolds. Maybe you can find one to fit that doesn't use the spacer.
Old 10-16-2011, 08:46 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
On the '85 F150 I parted the heat riser was on the driver's side. Don't know about an F250, but I think it would be unusual for Ford to swap sides.
Also, that one doesn't seem to have the shaft nor the butterfly it would have as a heat riser. And, the one's on the F150's had a vacuum motor. So, I'm not sure what it is, but I do yield to Dave's knowledge.
As for exhaust manifolds, I do have a pair from an '82 351W that didn't have the riser, plus the '85 pair with the riser. I could measure them this afternoon to see what the lengths are if need be. And, if there's an interest in either shoot me an email (janeyandgary@gmail.com) to discuss, although shipping would be expensive I would think.
Oh yes, please go into User Control Panel and fill out your location. Who knows, you might be in my back yard and I can help you.
Old 10-16-2011, 10:53 AM
jmmoore721's Avatar
jmmoore721
Trailering
it was on the driver side. and it had nothing in there just 2 holes for exhaust to blow out.
Old 10-16-2011, 01:06 PM
Stangrcr1's Avatar
Stangrcr1
Stangrcr1 is offline
That is where the heat riser was. The shaft, spring and valve are missing. Just plug the holes in the sides and reinstall.
Old 10-16-2011, 01:17 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Stang's got the answer. Here are some shots, but I apologize for the poor quality:
The top manifold is from an '85 351W HO, while the bottom one is from an '82 351W - both are driver's side. As best as I can tell both the manifolds have the same dimensions, but the '85 is flat where the outlet is while the '82 has the bell to fit the exhaust pipe. The '85 requires the heat riser to get the bell, but the riser is 1" thick so that changes the Y-pipe.
Here's the heat riser, and note that the flange is not broken, but cut off:
So, like Stang said, plug the holes and don't look back.
Old 10-16-2011, 04:34 PM
jmmoore721's Avatar
jmmoore721
Trailering
Thanks guys.. I'm at a loss as to why it was like this to begin with... I'm going to plug it as soon as I get back into town.. Thanks again!
Gary Lewis
33
03-09-2016 09:13 PM
svolpone
07-05-2015 03:23 AM
ImSoQuazy
Ford Truck Parts for Sale
01-21-2013 06:39 PM
cheddar89
03-01-2012 08:25 PM
ben73058
21
01-06-2011 11:30 PM
Quick Reply: 1985 F250 351w
