Code 44 during KOER, looking for direction
Here is a summary of the error you are getting with items to check:
Service Codes 44/311 and 94/314 indicate that Thermactor air system is inoperative.
Service Code 45/312 indicates that Thermactor air is misdirected.
Service Code 46/313 indicates that Thermactor is not being bypassed when requested.
Possible causes:
-- Vacuum hoses leaking, blocked or kinked.
-- Diverter valve, thermactor pump inoperative.
-- Air Management Solenoid(s) defective, blocked.
l Verify proper vacuum line routing in the Thermactor air system, including vacuum reservoir. Refer to VECI decal.
l Check for kinked or blocked vacuum lines.
l Check for kinked or blocked air hoses.
l Check for disconnected or cracked vacuum lines.
I assume your TAB/TAB solenoids and the rest of the AIR system are intact? If not, this would be a normal KOER test failure.
Possible causes:
Possible causes:
Possible causes:
Excellent direction, thank you
Andrew Baldwin
36
06-14-2018 09:57 AM
BLACK NITE
05-31-2006 02:36 PM
150, 302, 312, 44, 52, 75, 87, 91explorerthermactorcode46, air, code, f150, ford, koer, misdirected, thermactor
