Code 44 on Engine Running Test
Old Apr 30, 2006 | 04:26 PM
BLACK NITE's Avatar
BLACK NITE
Any ideas on what might cause a code 44 on the engine run test "thermactor inoperative<en dash> right side" that's what my haynes manual says. The truck is a 1992 F150 4X4 302 5 speed with air. Thanks for any info.
Old Apr 30, 2006 | 10:06 PM
tomandbeth's Avatar
tomandbeth
44 (r): Thermactor air injection system inoperative, bank #1. Suspect AIR pump, diverter valve, solenoids, harness.
Old May 28, 2006 | 10:15 AM
BLACK NITE's Avatar
BLACK NITE
Code 44 found
The code 44 was caused by a fine crack in the vacuum line going to the Diverter valve at the back of the engine, found it with my vacuum pump and vacuum gauge.
Old May 31, 2006 | 02:36 PM
mississauga's Avatar
mississauga
Good work. Looks like you diagnostics solved the problem real quick
