ABS Fuse location?
Old 10-14-2011, 09:21 AM
truckman72's Avatar
truckman72
truckman72 is offline
ABS Fuse location?
I would like to temporarily pull the fuse for my ABS until I can replace a sensor. I have a 1992 F350 4x4 w/460. Where is the fuse located? Is it labeled?
Thank you!
Old 10-14-2011, 10:04 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
I am not sure where it is but check the fuse box label in the cab...might be located there. But instead of going on a chase to find the fuse, just pull the positive side of the battery and replace the sensor. So you'll have to reprogram your radio stations...big deal...it's good practice anyway.
Old 10-16-2011, 09:22 PM
truckman72's Avatar
truckman72
I'm looking to pull the fuse until I can fix the issue with the ABS. I replaced the sensors and still have the slip issue and sometimes brakes lock up. I want to see if pulling the fuse makes a difference as well.
straightsixer
02-01-2008 08:02 PM
hgarcia85
Electrical Systems/Wiring
09-06-2007 03:18 PM
woodly1069
07-24-2007 11:49 AM
cross777
02-01-2005 10:17 PM
Quick Reply: ABS Fuse location?
