If I was as rich as my truck runs...(blue smoke)
This is a continuation for a different post, but since it's a new problem I'm starting a new thread. (Pre post... I was a dumba$$...)
She's a 89 F250 7.5L manual with o/d....
She smokes consistantly inconsistant. That is... I had a problem starting her (see pre post) and since found that issue but in the mean time, unclogged the AIR injection system diverter valve muffler (previous owner had it duck taped shut)...changed the PCV valve and grommet, found the number 5 and 7 wires to the wrong point on the distrumitor... am in the process of changing the O2 sensor....
...she runs smooth as silk, but smoke worse that Geroge Burns...inconsistantly... when I took her for a test run last night, she smoked for the first 5 mins or so... then would only smoke when I disengaged the clutch to shift... then took her on the freeway for about 5 mins and she cleaned up, a little puff of smoke when I "laid into her" to make a yellow light... so I decided to take are on a 15 mile trip up a hill to the next town, and when I got there she was smoking again.. then when I got home, just as worse as she was when I started... I smells like unburn fuel... you tell when it hits the eyes...
anyone else has such an experience or insite? thanks...
..and if they are black and look like there is oil on the threads???
...the person that worked on the truck before me had two of the spark plug wires miss wired, so she was running bad. This may have fouled them. Also, I just check the radiator and there is a slight milky film in the coolant, probably not good either...?
As far as the dead plug wires the plugs should be gas fouled (wet and stink like gas) not oil fouled (look's like liquid tar on and in the isolator).
Thanks for the insight! Here's what I did and how it went...
I changed the O2 sensor, oil, and plugs... she is not smoking (as much, only at first start up...) so I'm going to take her on the trip, well move 550 miles away...) I got some additive to add to the gas to clean the injectors etc....
Long story short... I think she will be good to go... thanks again...
-aa
-aa
michaelbrainardatwor
11-17-2006 07:25 AM
Hazardc
10-15-2005 11:01 PM
