rear anti lock brake light on
Old 10-12-2011, 12:22 PM
Nally427's Avatar
Nally427
Nally427 is offline
hey guys, my rear anti lock light keeps flashing on and off and as of just recently it just stays on the whole time. but the truck still seems to brake just fine. could the problem be from a bad sensor? and if so, where is the sensor located at? oh and the truck is a 5.0 AOD trans. 2 wheel drive
thanks
Old 10-12-2011, 12:34 PM
jimbo285's Avatar
jimbo285
jimbo285 is offline
Assuming you have a 92-96, I just learned this week that the Hydraulic rabs valve is on the left frame rail just downstream of the master cylinder. Has a 8" long wire pigtail coming out of it. The electronic module is behind the glove box. Approx 4"x6" block box. The sensor is mounted on top of rear diff and it is the vehicle speed sensor, so if speedo works good, probably not the culprit. These are the locations of the parts on my 96 F250.
Old 10-12-2011, 12:38 PM
Nally427's Avatar
Nally427
Nally427 is offline
yea i dont know if that would be the same as what i have. sorry i forgot to mention its a 89'. but it wouldnt hurt to go look to see if the setups are the same
DBANDGB
08-29-2017 05:39 PM
rusted&busted
07-27-2008 09:30 PM
DJdemon6696
08-02-2007 03:45 PM
HENDEL JR
06-19-2005 11:08 PM
florinsf
06-17-2000 11:09 AM
Quick Reply: rear anti lock brake light on
