v10 in a e350
First, you can't get 4.56 ratio. Second, that's going to get you well down around 6-9 MPG. Why would you want to do that? My '02 V10 extended E350 pulled my 9100 pound trainer just fine. It had a 3.73 axle. That's plenty of axle.
If you don't plan to race with a loaded van I would recommend the 5.4L to save gas money. It's not as fast, but the extended van is not much heavier than a standard length. When running a business saving gas money can be important.
HAHA, my 5.4 gets bad enough, no way I'd get a V-10, if you have money running out of your ears to pay for increased gas usage buy a diesel Chevy van, that's right, I said GM! The V-10's have a 5 speed trans, giving them the lower first gear, same final drive ratio, the lowest you'd want is 3.73's on one.
BTW my van is a 15 passenger 99 E-350 with over 1000 pounds of equipment to make it wheelchair accessible, Flowmaster 40 exhaust, an SCT, and intake modification. I live in Tennessee and spent a few years running back and fourth across the mountains hauling trailers, one being a heavy car trailer with a 96 convertible Mustang on it, in amazement it was doing 70 with enough power to go faster up a steep incline after a rest stop.
I believe the vacuum leak that's messing with my heat/AC is further ruining my mileage but at 150,000 miles who can complain about repairs when I've had nothing major.
The scale said my 15 passenger weighed 8000 pounds with my stereo and handicap conversion, plus me sitting in the front seat.
I pulled my loaded 22' pontoon, 14' dual axle trailer with 2 4 wheelers and gear, 200 miles to east TN to ride on regular basis, the boat was on it 4 times a week, I had to pull it up a drainage ditch at home to get it out too. I've never needed more power than the 99 5.4 provided, never had trouble towing anything the speedlimit on the interstate, even on Rockwood Mountain.
yes that is weight of van-my other 10 vans are 01-2011 e350s with 5.4's,my 04 with 350k is getting tired from being run hard,figured since i'm the owner, id treat myself to a v10
