Squeaky Clutch Pedal!!! :(
This noise happened last year!!! and it came back 2 months ago its driving me crazy the noise is coming from inside the cab like under the dash ive tried wd-40, grease, white lithium grease either im spraying the wrong spot or it just doesnt like me, any solutions???
on
WD-40 is not a good lubricant, in my opinion. It's meant to displace water and that's about it.
You need to find a good multi-purpose lubricant for the clutch linkage.
The owners manual states to use Ford #: C1AZ-19590-B and is a very good lubricant. The ford dealer should find you something simular to it if it's no longer avaliable.
I've also found a good multi-purpose lubricant that is close to the old Ford multi-purpose lubricant. "Max Professional: Super Lubricant"
Either one of these lubricants are good for clutch linkage and will stop squeaks associated with the clutch linkage.
Now if your squeaks are internal of the transmission, then you might have a begining of a more severe problem. Throw out bearing, worn clutch disc, etc...
I have this same problem in my truck. I've been trying WD-40, and it works for a while. Sometimes the squeak will come back, or sometimes it is more of a... 'crunch' almost. I've tried spraying the return spring, the shaft that goes down the floor, and the linkage between the two. Right now the squeak is gone entirely, but I feel in a few weeks it will return.
ArdWrknTrk probably has it right in his post above. The horizontal "pivot rod" (I don't know the actual name) that connects the clutch pedal to the belcrank arm which connects to the hyraulic master cylinder pushrod has plastic bushings on both ends. I think they are actually light green in color, you can see them peeking out at either end of the rod. These plastic bushings probably can wear out eventually and the result could be metal-to-metal contact on moving parts. That could cause a squeak. But I'm just speculating, I don't actually know. Maybe direct a squirt of proper lubricant at these bushings and see if that helps.
I had this problem and finally solved it.
There are TWO major moving clutch parts under the dash. The spring attached to the main clutch pedal might be squeaky, but there is also a linkage that goes up into the dash, comes down on the RIGHT side of the gas pedal, and goes through the firewall into the engine compartment.
I oiled the visible part of the right side linkage and the squeak is gone.
The horizontal "pivot rod" (7506) that connects the clutch pedal to the bell crank arm (7A554) which connects to the hydraulic master cylinder pushrod has nylon bushings (2471) on both ends.
These nylon bushings probably can wear out eventually and the result could be metal-to-metal contact on moving parts...causing a squeak.
When they wear, it sounds like a mouse is trapped under the dash.
EOTZ-2471-A .. Brake & Clutch Pedal Nylon Bushing / Available from Ford
Applications: 1980/96 F100/350 & Bronco.
