Differences in 4x4 frames?
on
Hey guys, I've recently found a good rolling chassis for $500. Comes with a 390, 4 speed and it's a 69 (ish he says) 4x4 frame.
I wanted to know if my 78/79 stuff will fit this frame (both my truck and the donor frame are longbox, but my truck is a 2WD)??
So basically I'm asking.. what are the differences between a 69 4x4 frame and a 79 4x4 frame?
on
Btw, what's the difference between divorsed and married t-cases? I've never owned a 4x4 yet (but I'd love to).
Hopefully this doesn't change your answer very much. I was enjoying doing minimal work to the bed to get it to work haha.
The difference with the front end is that on the frame you are lookin at the out put on it will be close to the ground where as the 77.5-79 exit at the top and are stronger. But good news is they are interchangeable. I say go for it. The bed is the only thing you need to re-drill to get to fit. everything else should bolt right up. good luck and post pics along the way.
southernboy0122
08-22-2010 09:18 AM
78ford351m
07-08-2006 09:10 PM
King Triton
09-03-2004 04:05 PM
