I second that. Most automatics and manuals I've dealt with share 1 switch for the brake lights, cruise control cancel, and in automatics the shift safety interlock, or whatever it's called.
Which parts of the switch did you test. According to the diagram it is a two part switch. One part is brake lights, the other is other functions, including the shift interlock.
Not sure what the differance is but my switch only has 2 pins on it. I have since found that my 4 ways don't work either.
With 4 ways off my turn signals work. With 4 ways on they don't, I don't know if this is normal or not.
Same switch location mine only has 2 spade connectors on it. However I did find the problem.
It ended up being one of the fuses for the multi switch, had 12v on the brake pedal switch when depressed and still no brake lights, so I just started pulling fuses. Found one blown and replaced 4 ways started and brake lights also worked.
Where is the best place to find a fuse block chart for this van? The cover of the fuse block was missing when I bought the van. Without a diagram it is a little difficult finding the problem.
