do the HP Dana 44 and Dana 60 use the same brake caliper?
Old 10-05-2011, 06:48 PM
vic_v8's Avatar
vic_v8
vic_v8 is offline
I don't trust the local parts store for the right answer.
Edit: I'm talking about the F250 44
Old 10-05-2011, 07:06 PM
Deluxetruck's Avatar
Deluxetruck
Deluxetruck is offline
I can't say for certain, but I'm sure they do. What I can say for certain is that the 77 highboy HD44 uses the same caliper as the HP/KP D60. That same style caliper was used into the 80's on the heavier TTB stuff, and maybe into the 90 for all I know. It has two pistons, the older style bolts together while the newer ones are one piece. They are retained on the bottom of the caliper by the I-beam looking deally with the spring. I apologize for being so technical.
-Jared
Old 10-05-2011, 07:08 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
I believe they do (as long as both are dual piston calipers).
Old 10-05-2011, 07:11 PM
vic_v8's Avatar
vic_v8
vic_v8 is offline
Yes, I'm refering to the dual piston. I have a 77 highboy and a Dana 60 for my 98, I'm getting some Braided stainless steel lines and wanted to see if I could buy two of the same set.
Old 10-05-2011, 07:36 PM
Deluxetruck
Another tool for cross-referencing auto parts is rockauto.com. Their site is easy to use, and you can catalogue part numbers for the 77 and see if they match those of the 79. Curious, what are you putting that 60 into that is a 1998 model?
-Jared
*EDIT* Just noticed your sig. My DD/ work truck is an obs 97 1/2 ton. I have a spare 60, and have been seriously contemplating a 60/14 bolt swap on it. Not sure if I could bring myself to use that axle on a Ch*vy though lol.
Old 10-05-2011, 07:37 PM
highoctane74's Avatar
highoctane74
highoctane74 is offline
as long as they are the dual piston, every one I have owned has been the same.
Old 10-05-2011, 07:46 PM
Deluxetruck
^^Same here, save for one. My brother had a rebuilt set on a ttb 50 truck(mid-eighties). I came across a ball-joint 60 for the truck, but the calipers mounted differently. I actually kept his D50 calipers for spares for my 60's. I can't remember what was different about that one set though. I'll have to call my brother, I'm sure he remembers.
-Jared
Old 10-05-2011, 10:44 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
I took mine off my 44 and they went straight onto my d60. They are the same
bigdan1979f-250
Offroad & 4x4
17
09-02-2016 04:49 PM
650
01-24-2016 05:39 PM
TheTowingCowboy
04-03-2012 03:29 PM
gingerbreadmaniac
05-08-2009 01:06 AM
lowboy250
04-08-2005 11:26 PM
Quick Reply: do the HP Dana 44 and Dana 60 use the same brake caliper?
