Mystery tubes
Mystery tubes
I am getting my plow truck (1997 F250) ready for the winter season and noticed something hanging below. Checking it out I discovered 2 tubes, one blue and one pink. I know a little about vehicle repair but not enough to figure out where these two guys are supposed to be connected. I traced the two back to the top of the engine compartment next to the firewall behind the battery. I've included a few pictures. Any help including pictures of where they should be connected would be of great help.
Well i'm not sure what all on these trucks is vacuum controlled. Does your cruise control work? Do all the heating/cooling controls including the flap that changes from cool to heat work?
You might stick your finger over the end of the tubes with the truck running and see if they're sucking air, if they are then they're vacuum tubes, if they aren't they might still be vacuum tubes and that's not the end they suck from. But if they were sucking at least you'd know.
Has your idle speed increased at all?
Redrokin09
278
01-08-2020 11:03 PM
ITSOT
08-28-2017 05:23 AM
Jarrett Campbell
05-13-2016 10:22 AM
dwhawkins89
11-27-2015 12:20 PM
