Top Dead Center on a 400
Old 10-03-2011, 08:58 PM
cyrrius's Avatar
cyrrius
cyrrius is offline
I don't trust that I have my distributor set right. Here's what I did:
I set #1 Piston as close to the deck as I could get and then set the dampers timing pointer to 0. Then I positioned the distributor to have the rotor pointing at the #1 point in it's original position (#1 is located at 1 o'clock). The vacuum points forward just like the original install as well.
The distributor seated successfully, but I'm wondering if I should have set the damper to something other than 0. This is all new to me so any help is appreciated.
dogmantra
10-04-2010 12:43 AM
shane1447
02-03-2010 03:49 PM
MMiller
05-02-2006 10:16 AM
ClatonK
10-22-2005 08:01 PM
Ben_E
06-27-2001 02:00 PM
Quick Reply: Top Dead Center on a 400
