Searched already-Pump Wiring-Help?
95 f250 5.8 4x4///Got the bed off and the pump out of the tank.-----The new pump has a red and a black wire, both stripped bare at the ends.--How do you connect these ( cut and solder leaving the connection bare??)No connections came with the new pump.-- This is kind of scary to me (bare electrical wires inside of a gas tank).Pls help!God Bless--John
///Do I have to worry about the connections in the gas itself (fire etc
// Do u mean the plastic coated butt connectors, Would soldering the wires to the existing wires be better??
on
Crimp butt splices are kind of hack to me. More so seeing how much work it is to get to them if one comes apart. I will use the crimp butts with the heat shrink built in to them But! not for this application.... Only one readily accessible to fix if need be.
This also states how stupid the NTSB finding was when they said a spark inside a full fuel tank of Diesel (same as jet fuel) caused the TWA flight to blow up near NY in mid air.
F150Texan
General Automotive Discussion
46
07-17-2004 01:19 PM
pwitort
09-14-2003 07:57 AM
radarsf150
05-06-2003 12:00 PM
