zf-5 slave cylinder
zf-5 slave cylinder
I have been trying to bleed the clutch and the pedal has some pressure and comes back up after being depressed, but it still does not disengage enough to allow the transmission to slip into gear. I have heard that if air is in the internal slave cylinder it can be hard to get out. Does anyone have any suggestions?
Bleeding a Concentric Hydraulic Clutch Set-up .: Articles Have a read through this article, may help.
I didn't use a vacuum pump when bleeding the clutch on my truck and it turned out fine. To start out, I opened the bleeder then slowly pressed the clutch to the floor, closed the bleeder, pulled the pedal back up and repeated that a few times. When I had a good flow of fluid during the pedal sweep to the floor, I closed the bleeder, pumped the pedal several times, then opened and closed the bleeder while holding the pedal to the floor. I repeated that several times to make sure I got all the air out.
78 & 87 Super Cab
29
05-26-2014 04:41 PM
rmalottwtes30
04-30-2010 11:47 AM
tr0y
03-15-2005 07:14 PM
Dr_Sin
11-22-2004 01:55 PM
