F-600 brakes
Old 09-27-2011, 04:42 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
F-600 brakes
Howdy all,
I am finally pulling everything apart. Pictures to follow!
I want to completely replace my single circuit boosted brake system with a hydroboosted (powered from the PS pump) double circuit system.
Does anyone have a suggestion as to which master cyl/hydrobooster would work ok with the 55 F-600 double-cyl rear brakes and single-piston front brakes?
I am planning to mount the MC/booster under the floor with the reservoir on the firewall.....but I can also do a hanging pedal if it won't fit.
Anyone been there/done that??
Old 09-28-2011, 02:57 PM
HT32BSX115's Avatar
HT32BSX115
Um...hello test......
Added some new pictures too. removed cab and set the engine in the chassis to measure for building engine and transmission mounts.
Old 09-29-2011, 06:07 AM
3414's Avatar
3414
3414 is offline
Wasn't there some discussion on this about a year ago? My thoughts are that a hydoboost assembly from a school bus or a medium truck that has roughly the same brake piston diameter as the brake piston on the old remote booster used on your truck would be a good match. I do not have the specs for the hydroboost used in the GM 4500 and 5500 trucks, but it might be s good starting point.
Old 10-14-2011, 03:06 PM
HT32BSX115's Avatar
HT32BSX115
Yeah I think you're right.
I haven't found any parts from one of those yet.
I am thinking that I might be able to just use an MC from a 3/4 or 1T truck.
I also think I'll probably have to use some sort of proportioning valve to make it all work right......
fusioncom
21
06-19-2006 12:09 PM
spencer5148
08-27-2004 05:00 PM
kcwelshans
06-14-2004 05:34 PM
chance_b
04-04-2004 09:45 PM
bremen242
10-30-2003 08:04 PM
Quick Reply: F-600 brakes
