Removing the front bumper.
Old 09-27-2011, 11:48 AM
Corrupt Silence's Avatar
Corrupt Silence
Corrupt Silence is offline
Question Removing the front bumper.
I was going to originally cut back the frame horns and pull the front bumper closer in to the front valance. After much thought and checking out many, many trucks at local shows, I have decided to remove the front bumper all together. Does anyone have a solid dimension that you know works? How far from the front of the frame horn should I go back to cut the horns and allow clearance for the front valance? After cutting the horns back, did anyone weld or bolt a cross member at the front of the new frame locations to act as a bumper behind the valance in the possibility of an accident? I'm down to bare frame right now, and am certain this is the direction I'd like to go. Any help in doing this would be very much appreciated.
Old 09-27-2011, 04:17 PM
Holmsey's Avatar
Holmsey
Holmsey is offline
I put my front valance back on and marked it, then cut it, that's all. But a crossmember as a hidden bumper would be a good idea.
Old 09-27-2011, 05:02 PM
Corrupt Silence
Thanks...
I am literally bare frame right now. I suppose it's one of the easier things to get too. I could just wait until I start putting body work on I suppose...
Old 09-27-2011, 07:05 PM
ben73058's Avatar
ben73058
ben73058 is offline
I'm putting fog lights in the two holes where the frame poked through.
Ben in Austin
Old 09-27-2011, 08:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The heavy ribbed bumper on '51-'52 was touted as strengthening the frame substantially. I noticed a difference when I got mine bolted up solidly. I don't see what a crossmember could hurt, especially with an IRS. They like rigid frames.
Old 09-27-2011, 09:24 PM
arrowheadfred's Avatar
arrowheadfred
arrowheadfred is offline
A cross brace is a good idea. I like the running light idea also. That will look good !!!! Maybe even cut a flat spot in the middle for a front tag. If ya did something like this and used a fliped down tag you could even weld a tow hook to the brace just in case you need to pull it.
Old 09-29-2011, 10:50 AM
Holmsey's Avatar
Holmsey
Holmsey is offline
Yeah I would 2nd tow eye. Wish I had fitted one... well ya never know I may do over the winter and make a brace to ;o)... thanks for the ideas
slinginsaws
02-18-2015 07:18 PM
TwistedFate
03-21-2012 05:20 PM
Corrupt Silence
02-12-2011 12:24 PM
Fireman33
1978 - 1996 Big Bronco
01-24-2003 11:31 AM
oft
12-16-2001 09:23 PM
Quick Reply: Removing the front bumper.
